3500 hesitation
Old Dec 27, 2001 | 11:29 AM
LITESPEED's Avatar
3500 hesitation
I am considering buying an '88 GXL 2+2. The original owner told me there is a hesitation or hiccup as he said at 3500 rpm's. Is this a serious problem or what? I've read elsewhere there is a fix that usually works.
Is this a problem that should make me wary. The car only has 80k miles on it.
Thanks in advance!
Old Dec 27, 2001 | 11:48 AM
Josepi's Avatar
Despise Enmity
That's when the secondary ports are supposed to open up around 3800 rpm. Where at in VA?
Old Dec 27, 2001 | 11:49 AM
Josepi's Avatar
Despise Enmity
But to answer your question, most people just finangle them open for a quick fix. Look at the top of the screen and you shall find a search button. Do a search in this forum for 3800 rpm hesitation. Answers will follow.
Old Dec 27, 2001 | 12:45 PM
LITESPEED's Avatar
LOCATION OF RX-7
It is in Arlington Va. He says it needs a tune up and possibly shocks. Tape player doesn't work, and sun roof needs a little help to pop up but after that it operates fine. I'm just worried about that hesitation but I'll read the posts you directed me to. BTW, he's asking $3900.00
Old Dec 27, 2001 | 12:53 PM
Fc3sracer's Avatar
IF its got high milage i wouldnt pay more than 2500 well maybe 3000 at most. But youll be happy with the car if you get it. Just make sure to get a compression check done. Most of those problems are easy fixes.
David
Old Dec 27, 2001 | 01:02 PM
LITESPEED's Avatar
mileage
It has 80,000 miles on original engine. Not bad for a 13 yr old! Driven by his wife. She has a Boxster now!
Sethix
Nov 3, 2017 11:48 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
eplusz
15
Oct 7, 2015 04:04 PM
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
