Wrapping manifold back!?
Old Apr 7, 2005 | 09:32 PM
cripsR6's Avatar
11.7@128
Exclamation Wrapping manifold back!?
I am running a 3rd gen with a single turbo(Gr67{t66}) stainless manifold, downpipe, and midpipe with titanium exhaust. My question still, after searching, is whether or not I should waste my time wrapping the manifold, and the rest of the exhaust system in order to increase its efficiency somewhat as well as keep engine bay temps down. I have also been contemplating a turbo blanket as well. If anyone could share their experiences, I would greatly appreciate it. thanks.
Old Apr 7, 2005 | 10:42 PM
RX7WEEE's Avatar
Need a 20b FD.
You should wrap the manifold and the downpipe anything after that is almost useless, unless you want it like 1 DB quiter :P
A heat shield for the hotside of the turbo would also help.
Old Apr 7, 2005 | 11:36 PM
bcty's Avatar
Boost This!
i find the wrap also helps with the sound
less tinny
but yes wrap it
Old Apr 8, 2005 | 12:18 AM
1sicsol's Avatar
How much does that stuff go for?
Old Apr 8, 2005 | 09:13 AM
bcty's Avatar
Boost This!
50CAD for me for a 2" wide by 50 foot roll
theres tons of stuff to use
Old Apr 8, 2005 | 09:46 AM
2a+RoN's Avatar
is wrapping beneficial if the manifold has already been ceramic coated?
Old Apr 8, 2005 | 01:39 PM
RX7WEEE's Avatar
Need a 20b FD.
Wouldnt hurt anything, plus it will keep in more heat.
Wrap everything
Old Apr 8, 2005 | 03:18 PM
93silver3rd's Avatar
RotaryPowered to you...
i have that same kit and i had to get a heat shield because the turbo started to burn through the heat shield on my heater hose..... im glad i caught it before it actually burned all the way throught the hose.
Old Apr 8, 2005 | 03:35 PM
jasrx's Avatar
yes wrap it up ,you might need a couple of packets but its well worth it . i wrapped my exhaust till the drivers seat [ to help keep the heat out of the auto].
Old Apr 8, 2005 | 06:34 PM
cripsR6's Avatar
11.7@128
Question
Heat shield, or turbo "blanket"? I'm a lil confused. Btw, thanks for all the feedback so far.
Old Apr 9, 2005 | 02:36 AM
I just used a shield that RP had laying around from someone else's kit. Like i said, the hot side of the turbo was directly touching the heater hose thermal wrap. it melted through the wrap in about a week. Blanket is the best solution, but the shield was cheaper.
C. Ludwig
Jan 30, 2019 06:31 AM
Microtech
30
Apr 23, 2016 06:37 PM
82streetracer
Aug 23, 2015 09:28 AM
