how to take off the bolts
Old Apr 7, 2005 | 02:53 PM
zeromage428's Avatar
BWAAA
Angry how to take off the bolts
i was wondering how to take the bolt off the bottom part of the shock??? the one that attaches it to the wheel or whatever, im a nub at this so could someone help me?
it seems like it is impossible for it to move
Old Apr 7, 2005 | 02:58 PM
DamonB's Avatar
You mean the nut at the end that holds the spring on the shock or literally the bottom of the shock where it attaches to the suspension?
If it's the nut over the spring you must compress the spring a little to take tension off the nut. The piston rod normally has a flat or hex on the end so you can hold it from turning with one wrench while you remove the nut with another.
If you're talking about the bottom of the shock where it bolts to the suspension you first need to jack the chassis up high enough that the weight is off that corner of the suspension. Then the only weight on the bolt will be the weight of the suspension itself. If you don't jack up the entire end of the car you'll have to disconnect the sway bar too.
Old Apr 7, 2005 | 03:55 PM
jgrewe's Avatar
GET OFF MY LAWN
If it's rusted frozen and is trying to turn the bushing in the shock when you crank on it, use a sawzall on each side of the shock(inboard from suspension metal) to cut the bolt.
Old Apr 7, 2005 | 05:15 PM
BWAAA
i cant even crank the bolt...either im not strong enough, or is it safe enough to try n let pb buster sit on it for a little n then try?
Old Apr 7, 2005 | 08:06 PM
BlueRex's Avatar
If you can't even turn the bolt it makes me wonder if you have the right tools for the job? Honestly having the right tools for the job makes it so much easier
While I myself haven't done any suspension work on any RX-7 I know from working on suspension components on other cars that PB Blaster, a good breaker bar with a cheater pipe, some good open and closed end wrenches can pretty much take care of any bolt. But there are some stubborn ones, keep trying.
And obviously take DamonB's advice if the bolt need to be relieved of tension.
Old Apr 7, 2005 | 11:37 PM
jgrewe's Avatar
GET OFF MY LAWN
Blaster is great stuff, soak it over a few days. If that doesn't work refer to my earlier post. Even with some tension or pressure on them you should be able to turn them in the shock bushing a little. If you can't turn them you won't get them out ever. Resist heating them because rubber is a self fueling fire.
Old Apr 9, 2005 | 07:01 PM
hotrodrx7's Avatar
Soak it with PB Blaster or Liquid Wrench and borrow an air wrench.
Old Apr 12, 2005 | 10:06 AM
igottafc's Avatar
RX7less **(
i had the same problem when putting in my setup. I used a shitload of PB blaster, a ratchet and a 2 foot pipe (its the longest i had). I just stood on the pipe and pulled down on my bumper and both sides broke free with relative ease. Its the fronts that took me about 4 hours on each side.
Jetlag
Sep 29, 2015 06:52 AM
