hesitation just before redline
Old Dec 21, 2001 | 09:36 PM
mazdaspeed7's Avatar
mad scientist
Im having some hesitation between 7500 and 8000 rpm. The engine stumbles a few times in that range, then at 8K, feels normal, and pulls like crazy until the rev limiter. I believe it is ignition related, but it is not with the plugs or wires, both are pretty new. I have my timing advanced, and I tried retarding it back to normal, and it made it worse. Much worse, the engine felt like it was really struggling for those 500 rpm. Could this have something to do with my Crane ignition? I have the rev limiter on the crane set to 8800 rm, same as the fuel cut the stock ECU uses. Any ideas?
Old Dec 22, 2001 | 04:06 AM
ROSHX7's Avatar
Yep, mine did the EXACT same thing. Problem: Faulty Throttle Position Sensor. Specifically its giving the computer BAD readings at WOT. The computer goes crazy does all sorts of crazy things. Solution: Get a good Throttle Position Sensor. Problem will be GONE!
Old Dec 22, 2001 | 04:48 AM
UniqueTII's Avatar
Slow and old
Agreed. I had all the same symptoms on my TII and the TPS was to blame.
Let me tell you something about TPS reports.
Old Jul 31, 2004 | 01:13 AM
driftseshrx7's Avatar
six 8 l l 8 port
had same here,w/ stock ignition s4 n/a,, new tps took care of it
Old Jul 31, 2004 | 02:53 AM
RotaryResurrection's Avatar
Drift, is there any way that you can NOT bring back 3 year old threads? IT'd be much appreciated.
Old Jul 31, 2004 | 03:01 AM
razorback's Avatar
You've Been Punk'd
Old Jul 31, 2004 | 04:03 AM
razorback's Avatar
You've Been Punk'd
btw i got the oil control rings. thanks again.
Old Jul 31, 2004 | 11:16 AM
Fritz_X's Avatar
At least he is searching Kevin . Better than half the other new forum members that post the same sh*t we had yesterday, and the day before that, and the day before that. At least this isn't wasting more bandwith lol.
Seriously though, if all you are going to say is "yeah, me too" to a 3 yr old post why not just leave it dead?
--Fritz
Sethix
Nov 3, 2017 11:48 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
lnlreaper
Sep 27, 2015 09:59 AM
