3rmp hesitaion
Old Dec 15, 2001 | 08:45 PM
richmonie's Avatar
Newbie
Unhappy doesnt rev to 3rpm
My car doesnt rev to 3 rpm's no more. I put octane booster in my car and when i started it up on a cold start it worked. Then later in about 4 days it wouldn't go to 3rpm. Should i put more octane booster i mean my car is still 3/4 full of gas. Also lots of white smoke would come out from my exhaust when i first start my car. For a good 3 mins then it would go away. Can someone help me please. Thank you
Old Dec 15, 2001 | 09:00 PM
evot23's Avatar
Classy
Are you talking about the AWS? Also some smoke at startup is not entirely uncommon. Mine does it for a few minutes and then goes away. Does it smell like coolant?
Octane booster will do nothing for getting the AWS to 3000.
Old Dec 15, 2001 | 09:06 PM
Dragon's Avatar
20B N/A Wide Body FC3S
I'm assuming it's cold where you are at... do you know how when it's cold you can see your breath, well you are just seeing the water vapor from combustion untill the engine warms up... also rotory engines don't like the cold and can be a pain to start in cold weather especially if your spark plugs are old, octane booster will only foul out the plugs that much faster...
Old Dec 16, 2001 | 10:42 PM
richmonie's Avatar
Newbie
Its is not cold where i am from. I'm from california. It is really warm here. The smoke doesnt smell like coolant. Do you guys know why it won't rev to 3rpm anymore?
Old Dec 16, 2001 | 10:44 PM
Johnny's Avatar
OG
actually you should not want it to rev to 3K anyways...blip the gas on start up.let it warm up and dont worry about it..
Old Dec 17, 2001 | 01:08 AM
GoRacer's Avatar
Speed Mach Go Go Go
The 3k wark up is normal
It is Mazda's version of a choke.
You want to check the "Double throttle control" line. It may have popped off, cracked, split etc.
Click below for diagram...
http://www.fd3s.net/Reference/images...oses.color.jpg
Old Dec 17, 2001 | 05:54 AM
CantGoStraight's Avatar
What's your point ?
3k ?????
Richmonie,
Are you saying that it won't go over 3ooo rpm at all ????? I re read your post and can't ell if your saying it will not go over 3k rpm at all or are you talking about the warm up rpm ????
Old Dec 17, 2001 | 04:31 PM
Dragon's Avatar
pull off the ground from the battery and press the brake pedal to reset the computer... your car will have to relearn idol, but I've seen a couple FD's that were doing somthing simular and it was the computer freaking out...
Old Dec 18, 2001 | 03:54 AM
Zero R's Avatar
Just in time to die
First off if your talking about AWS you don't want it to rev to 3k right after start up it's not a good idea to have any motor rev like that without being prelubed let alone a rotary. To bypass tha AWS just hold down the clutch put it in first gear and start the car, then take it out of first gear and let out the clutch, (AWS is not needed).
FcBoosting
15
Aug 10, 2010 11:20 PM
13Beezies
Apr 1, 2010 04:19 AM
1revin712488
26
May 17, 2008 10:59 PM
Relisys190
May 3, 2003 11:54 AM
khoney
Sep 6, 2001 01:28 AM
