Power FC Power FC question.
Old Jan 11, 2005 | 08:55 PM
crepete's Avatar
Power FC question.
I just received my Power FC from Japan, and low and behold, the instructions are japanese (big surprise). I ordered the new comp because I put 1600cc injectors in the car. For some reason, I cannot set the the injector size bigger than 1500cc with the commander. I have not actually run the car car yet, as it is snowing heavily and I am still waiting for my fuel pressure regulator. My question is : Can you set the injector size to 1600cc using the commander, or do you need the datalogit software to do it?
Old Jan 11, 2005 | 09:30 PM
iluvmy3rdgen's Avatar
I live in a Museum
This is the wrong section. Where is highland in New York?
Old Jan 11, 2005 | 09:33 PM
Rotarded's Avatar
"Challenged" since 1993
you need the datalogit software to do it!
Old Jan 11, 2005 | 09:35 PM
AgentSpeed's Avatar
BNR built motor and twins
I believe you need the datalogit for 1600's. The commander will not let you go that high.
Old Jan 11, 2005 | 09:42 PM
crepete's Avatar
a) Highland is by poughkeespsie, about 6 miles away, why do you ask? b) Sorry for posting this in the wrong section, I just figured since I had a 3rd gen it was the correct spot c) Thanks for the info.
Old Jan 29, 2005 | 07:55 AM
DaV"srx7's Avatar
D's-Rx7
the cost on the datalogit&pcf??
Old Jan 29, 2005 | 03:44 PM
Tim Benton's Avatar
FD title holder since 94
cost of the datalogit and software is 339 for a serial port connection to your laptop. The PFC price varies depending on the dealer, anywhere from 1100 to 1250 new from a seller. 850 from some guys in Japan.
www.rx7.com has both
Tim
Old Jan 29, 2005 | 05:58 PM
rynberg's Avatar
Not only do you need the datalogit, but you will need the correct resistors for those injectors -- otherwise you may blow out the ignition drivers in the PFC.
Old Jan 30, 2005 | 11:54 AM
APEXL8T's Avatar
boxed in and drawn out
So is this needed for the 1600 secondaries that Gothemracing sells too?(KG rail)
Old Feb 1, 2005 | 01:34 PM
crepete's Avatar
Thanks for the info. From what Keith at kgparts says, the correct resistors are 10 ohm 10 watt resistors.
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
