beep beep beep beep beep!!!!!!!!!!!!
Old Dec 9, 2001 | 02:51 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
my 87 GXL makes a five beep series after a few minutes of driving. it immediately stops if i make a hard left turn or jerk the wheel to the left.
some have said it might be the power steering pump. but i dont want to spend 150$ on a hunch. does anyone know what this five beep code means?
Thanks
Justin
Old Dec 11, 2001 | 09:54 PM
fc3s94509's Avatar
i heard it was the p/s pump also, but im not sure i hope you figure it out though
Old Mar 16, 2002 | 11:49 AM
is it 5 beeps then 5 beeps then 5 beeps? and it just keeps going ? if it is then it is a short in your wires somewhere from the power steering computer to your steering wheel or out to the pump . It sucks mine did this for months till I replaced my turn signal switch on the colum. I had a broken wire !!!!
Old Mar 17, 2002 | 06:00 PM
SanJoRX7's Avatar
uid 0
The FD sunvisor stuff says that groups of 5 beeps are indicative of a problem with the airbag. I dunno anything about FC's or FB's though, so it's probably something different. Worth noting though...
Old Mar 20, 2002 | 08:21 AM
RETed's Avatar
__________________________________________________ _______
I had a similar problem with a recently purchased '86. I would be driving
along when a beeping would emit from inside the dash. Soon after, my power
steering would feel more like manual. I checked my factory service manual
and discovered that the Speed Sensing Power Steering control unit, located
under the dash below the instrument panel, emits beep codes to indicate a
problem. There are six different conditions/codes:
1) 2-beeps, pause, repeat. In case abnormality occurs to the engine speed
signal. The buzzer sounds when the vehicle speed signal is input and no
engine speed signal is input (short circuit, broken wire, etc.)
2) 3-beeps, pause, repeat. In case abnormality occurs to the stepping motor
signal. The buzzer sounds when there are broken wires or short circuits
in coils or harnesses.
3) 5-beeps, pause, repeat. In case abnormality occurs to steering sensor
signal. The buzzer sounds 60-seconds after broken wire or short circuit occurs
to sensors or harnesses when the vehicle speed is above 40Km/h (25 mph.)
4) 1-beep, pause, repeat. In case abnormality occurs to speed sensor signal.
In case broken wires or short circuits occur to sensors or harnesses, the
buzzer sounds 60-seconds after the engine speed signal of 2200 rpm continues
for 18-seconds.
5) Continuous beep. In case abnormality occurs to the power steering
microcomputer. The buzzer sounds if the microcomputer becomes abnormal and
cannot control the system.
6) 4-beeps, pause, repeat. Also in case an abnormality occurs to the power
steering microcomputer. The buzzer sounds when there are circuit troubles
other than with the micro computer.
My beep code was #4 from above. I removed the control unit from my car,
opened the metal box it was in, removed the circuit board and resoldered it.
Upon re-installing, everything was fine. You might also want to first just
try removing the connector to the control unit, cleaning it, and then re-
connecting. I'm wondering if this could have fixed mine.
-Ted
Old Nov 19, 2007 | 10:35 PM
ghalee-fc's Avatar
can you help me out.
my fc has a Continuous beep.
how can i get rid of it.
Blastfastrotary
Sep 11, 2015 12:26 AM
charger-
Jan 31, 2003 05:43 AM
M.C. Language
20
Dec 5, 2002 04:25 PM
M.C. Language
May 9, 2002 12:26 PM
JDuncan
May 1, 2002 12:27 AM
