Problem removeing butterfly from the upper intake
Old Dec 8, 2001 | 06:49 PM
Rx7aholic's Avatar
Hey I ran into a slight problem trying to removed the butterfly from the upper intake manifold. How do u guy's removed that butterfly? oh yeah I already trip screw's there is no head left on the damm screw. How can i fixed that? please help thanks, khris
Old Dec 8, 2001 | 07:29 PM
MeLoN350's Avatar
I stripped my screws out on the last manifold I did, had to drill them out. It is no big deal, just start with a small drill bit.
Nick
Old Dec 8, 2001 | 08:44 PM
Flybye's Avatar
It's never fast enough...
It's simple. The screws on the shaft have a tendacy to swell up at the end making it difficult to screw out. All you need to do is take a chisel, remove the end of the screw sticking out of the rod, and it should be easy to screw out there after
Old Dec 9, 2001 | 12:20 AM
Rotaree's Avatar
Easy Fix for Stripped Screws
If they are phillips-head, which I assume they are, cut a groove in the top of the head of the stripped screw with a hacksaw if there is enough exposed to do so. This way you can use a flat-head screw driver to take the screw out.
Old Dec 9, 2001 | 06:19 AM
Drill out the screws. The ends are mushroomed flat to prevent them from dislodging into the tract.
Use a long nose pliers and work that disk out. It might be difficult due to the burrs created by drilling.
FD7KiD
15
Feb 26, 2021 10:12 PM
Snoopy FD
Dec 8, 2015 01:45 PM
FD7KiD
Aug 17, 2015 11:50 PM
