12A smokes...Help
Old Nov 28, 2004 | 05:26 PM
Peanut7694's Avatar
Noob
12A smokes...Help
Ok, just bought an 83...its ugly beat, and kinda slow....it runs good just getting weak with age...here comes the question, at about 4.5-5.5k rpm it smokes really bad. now here comes the question, how can I minimize the smoke? I was thinkin and oil-change and some stop smoke treatment, I can't afford a rebuild right now, so i am looking for cheap suggestions
Old Nov 28, 2004 | 05:33 PM
Latin270's Avatar
what color is the smoke??? Had a simialr problem and found that the O-rings in the intake were old and cracked and caused coolant to leak into the engine. Changed the gasket and o-rings and she's been running great!
Old Nov 28, 2004 | 07:34 PM
YapaKanichi's Avatar
Smile Like a Donut
most likely it's your oil control rings if it's bluish. Only a rebuild will fix that problem. But it's not a big big problem, just keep an eye on your oil level.
Old Nov 28, 2004 | 08:38 PM
therotaryrocket's Avatar
PIMP
Do you have to top off any fluids? Could even be brake fluid through brake booster, if the smoke is black (too much fuel)..then choke could be slightly sticky
Old Nov 28, 2004 | 11:09 PM
Peanut7694's Avatar
Noob
its blue smoke...burning oil...I guess I will deal with it, keep a quart of oil with me at all times, anyone think that stop smoke treatment would help or would it be more harmful to the engine?
Old Nov 28, 2004 | 11:13 PM
Paradox's Avatar
backyard tuner
id stay away from the stop smoke stuff, since it could gunk up your apex seals
Old Nov 29, 2004 | 12:24 AM
GavinJuice's Avatar
Leave A Message
that **** is bogus and does nothing but swell your seals, which is the point, but it turns them to mush in the process.
Old Nov 29, 2004 | 01:22 AM
brandon davis's Avatar
okay i too cant afford a rebuild like some of us here but you can find a good motor for 300 or less and is stupid easy to install by far the least involved motor swap ive ever done for the least amount of bling all you need is a 10, 12 , 13,14,15, and a apex tip screwdriver and 2 more guys a 2x4 and some nylon strap and you too can install a rotary motor in 1 day no bullshit.
Old Nov 29, 2004 | 07:42 AM
Peanut7694's Avatar
Noob
well, if its that easy...maybe I will do that 13bt down the street...the whole car is sitting there totaled
Old Nov 29, 2004 | 11:10 AM
numan2's Avatar
whipmebeatmewankelmeoff
I'd do it if there was one down the street from me
Old Nov 29, 2004 | 03:30 PM
calvinpaul's Avatar
Mmmm Cheeze....
Ha ha ha, a 2x4 and some nylon strap....classic and true!!!!
Andrew7dg
Aug 6, 2017 01:41 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
