no trailling
Old Nov 17, 2004 | 07:25 PM
DrifterFC's Avatar
no trailling
if i remove the trailling plugs and coil will i lose power and driveability
Old Nov 17, 2004 | 08:18 PM
rotarygod's Avatar
Rotors still spinning
A little bit. Not much. Why would you do this?
Old Nov 17, 2004 | 11:21 PM
patman's Avatar
Resident Know-it-All
dude...we already answered your question in the 2nd gen section..why do you want to do this so bad anyway?
Old Nov 17, 2004 | 11:32 PM
Jeff20B's Avatar
Lapping = Fapping
You probably won't notice it at all.
Old Nov 18, 2004 | 09:48 PM
bbmac's Avatar
you won't notice a huge power drop but your fuel economy will go down.Not sure how much. the trailing ignition system was implemented because of the rotaries elongated combustion chamber and because of the length of the chamber it created an inability to combust the last 15-25 percent of the fuel mixture. this is mainly for emissions control but why would you want to eliminate it? If it isn't broken don't fix it........
Old Nov 20, 2004 | 02:48 PM
DrifterFC's Avatar
i was just wondering
Old Nov 20, 2004 | 07:11 PM
ErnieT's Avatar
Living life 9 seconds at a time
This is what KD Rotary calls their "Anti Detonation" Top Secret $500 BULLSHIT device. They back out both trailing plugs and install "buttplugs". What a total crock. People have went out of business for less.
Old Nov 20, 2004 | 07:13 PM
rotarygod's Avatar
Home Depot has them for a few cents in the nuts and bolts department.
Old Nov 22, 2004 | 11:15 PM
BATMAN's Avatar
Does eliminating the trailing allow you to run a leaner A/F ratio since more unburnt mixture helps cool the rotors down?
If so that might help in power density, no?
Old Nov 22, 2004 | 11:50 PM
andrew lohaus's Avatar
um why would you think less ignition would make more power thats the dumbest thing ive ever heard.
the r26b used 3 plugs per rotor to get more complete combustion. more complete combustion is good for everything, fuel economy, power, emissions, etc.
face it there is no performance or relibility advantage to this.
the only posible advantage is simplicity, and its not like the ignition is THAT complicated as it is....
Old Nov 22, 2004 | 11:56 PM
BATMAN's Avatar
Just a thought from reading the anti detonation device threads
tryskriel
Haltech Forum
Nov 12, 2010 01:49 AM
13bdarren
Megasquirt Forum
Oct 28, 2008 04:04 PM
potatochobit
Sep 9, 2005 04:29 PM
