Just stopped running
Old Dec 4, 2001 | 08:09 PM
LongBoardLarry's Avatar
One minute I was driving and the next there was a little spudder and then it died and won't start.
I have spark so I am thinking fuel pump.
But when I was looking to see if I could see any fuel spraying into the carb I also notices that the throttle sub-return spring end that goes to the choke return diaphram was missing.
Ok so the question is how do I check to see if the fuel pump is working? and were do I get the end piece for the sub-spring.
Thanks
Old Dec 4, 2001 | 08:29 PM
SilverRocket's Avatar
EliteHardcoreCannuckSquad
I'd say it's most likely your fuel filter. Definitely replace before doing anything else.
To check the fuel pump, pull the main fuel-in line at the carb. Then turn the ignition to "on" and the fuel pump should start running and spitting fuel out. Grab a metered container - it should dump out about 1-1.5 liters in one minute.
Old Dec 4, 2001 | 10:36 PM
Thanks I will replace the fuel filter first.
streetlegal?
Mar 17, 2022 02:46 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
smikels
Aug 18, 2015 01:26 PM
