Oil Pressure guage/Sender issues
Old Nov 4, 2004 | 04:08 PM
barcode's Avatar
I recently swapped my motor and hooked everything back up. Everything works now but my oil pressure guage. With the sender that came in my car it goes way below zero with the ignition off and then as soon as you turn it to on the guage pegs way above 110. I grounded out the wire that attaches to the sender and the guage moved, so I know it's a sender problem. Trouble is, I bought a new sender and it now reads nothing, doesn't even jump with the key on. Any thoughts?
Old Nov 4, 2004 | 04:18 PM
Sith_Lord's Avatar
I had the same issue with my car. So I just installed a SunPro guage. It seems way more accurate to me.
Old Nov 4, 2004 | 04:20 PM
WAYNE88N/A's Avatar
Are the sender & housing threads nice and clean for a good ground?
Is the capacitor installed in the circuit (bolts to the slave cylinder)?
Could be bad from stock- wouldn't be the first time...
You didn't fry anything while grounding that sender wire (like the gauge), did you?
Old Nov 4, 2004 | 04:26 PM
Corbit's Avatar
what is the capacitor
Old Nov 4, 2004 | 06:13 PM
WAYNE88N/A's Avatar
Kenteth & the guys have a civil discussion about this very animal going on in another thread as we speak...
The cap (short for capacitor) in this case is the little black "box" that bolts to the clutch slave cylinder. In the oil pressure sender circuit, it acts as a noise filter, by shunting (or "dumping") to ground any EMF pulses induced into the wiring by the ignition system, so that the gauge readings won't be skewed. Many guys have said that their oil pressure gauges run fine without it in the circuit, which means that the plug wires aren't close enough to the wiring to cause problems. Picture the cap as being a dam on a river. It stores electricity just as the dam stores water, but when a voltage spike (heavy rain) occurs in the circuit (river), the cap (dam) discharges the excess safely to ground levels to prevent damage to the circuit or erroneous gauge readings/twitching...
Old Nov 4, 2004 | 10:47 PM
Corbit's Avatar
WAYNE88N/A you are the man , thanks for your answers
Old Nov 4, 2004 | 11:41 PM
Icemark's Avatar
more accurately called the Condensor, rather than the Capacitor
Old Nov 5, 2004 | 12:34 AM
RotaryEvolution's Avatar
Sharp Claws
friends don't shock friends with condensers... or maybe they do!
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
