Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
Intake, DP, CB, IC: Safest ECU?
Old Oct 27, 2004 | 02:17 PM
LAracer's Avatar
My goal for this car is to keep it reliable. It has low mileage, and I'd like to keep it from popping for a long time. The car already had IC, intake, and CB when I bought it, and I added the rest as "reliability" mods. I keep boost at or below stock levels. I'm wondering whether should I upgrade the stock ECU with an M2 or something similar?
My thoughts are:
Stock = possibly lean
M2 = Probably not lean, but maybe tuned more aggresively at the expense of engine life (???)
So the question is, which ECU will make my motor last the longest (assuming no other mods).
Any help appreciated
Old Oct 27, 2004 | 03:02 PM
RETed's Avatar
No such thing
-Ted
Old Oct 27, 2004 | 03:12 PM
rynberg's Avatar
You are perfectly fine with the stock ecu at 10 psi. A "chipped" ecu like the M2 will allow higher boost levels, which will, of course, shorten engine life. If an engine only lasts 80k, that is typically at least 8 years of driving.
Old Oct 28, 2004 | 08:51 AM
LAracer's Avatar
Thanks Rynberg. I'll stick with stock ECU and stock boost.
Old Nov 12, 2004 | 10:17 AM
EFS.O's Avatar
How you manage to keep the boost at 10 psi(Besides the profec)?Have you ported your wastegate?
C. Ludwig
Jan 30, 2019 06:31 AM
Snoopy FD
Dec 8, 2015 01:45 PM
Engine stand ready
Aug 14, 2015 10:26 PM
