will these tires/wheels fit my FD?
Old Oct 26, 2004 | 09:35 PM
Zer0 Cylinder's Avatar
hi, i have a friend with some stock 5lug 300zx wheels...not as important as the tires, but will the wheels bolt up to the FD?
im more concerned with putting the tires off of the wheels onto my stock fd wheels.
the writing on the tires are:
front: 225-50-92v
rear: 245-50-96v
thanks guys!
Old Oct 26, 2004 | 09:46 PM
apex_sideway's Avatar
FD dream is dead
Whats the bolt pattern? Offset? Tiresizes don't seem like a big deal . . . i'm not a forum expert though
Old Oct 26, 2004 | 09:47 PM
SpeedKing's Avatar
Power Trippin'
Z32 ('90-'96) wheels? The bolt pattern is the same, but the offset for those wheels are a lot lower so you may have rubbing up front. And those tires should work; 225/50 comes on a stock FD (you didn't know that? ), and you should have enough clearance out back to run 245/50.
Old Oct 26, 2004 | 09:49 PM
FD dream is dead
Hehe, after a year of, "You didn't know the sizes and offsets you dumbass" from speedking i've learned a little about offsets and what might fit in the seven and not. Thanks Speedking
Old Oct 26, 2004 | 09:52 PM
rynberg's Avatar
245/50 is too tall by almost an inch. Won't be good.
As far as the wheels, I think the offsets may be too low. There might also be a centerbore issue. That and they are really heavy.
If you need new tires, just get some new tires. If you can't afford them, you shouldn't have an FD anyway.
Old Oct 26, 2004 | 10:00 PM
SpeedKing's Avatar
Power Trippin'
He asked for rear fitment, and although I myself don't recommend this size, they should clear out back.
I used to own a '91 300ZX Twin Turbo. You are correct on the offsets. I had that car for 5 years and can't remember for the life of me what it is right now but it's something like +32 or +35. Don't think there would be a centerbore issue, but Z32 wheels are NOT heavy. Stock 16" wheels weigh 16 lbs.
Old Oct 26, 2004 | 10:03 PM
hmmmmm one's saying the 245-50's will fit in the back..the other isnt....
yea, screw the wheels, i dont care about them, i just want the tires for my stock wheels.
Old Oct 27, 2004 | 10:41 AM
rynberg's Avatar
Yes, the 245/50s will fit in the rear. However, they are almost an inch taller than stock which will jack up the rear of your car and raise your final drive ratio, slowing acceleration.
Sorry for the bad info, I must be thinking of another car.
Old Oct 27, 2004 | 01:26 PM
slowing acceleration...how much?
i think maybe the amount that i spin now, compared to this, will work out better for me to have these tires.
cewrx7r1
15
Aug 6, 2018 11:41 AM
rx7jocke
72
Jun 17, 2016 03:48 AM
BLK 93
11
Sep 9, 2015 10:56 AM
