Oil Pan Brace
Old Sep 27, 2004 | 03:50 AM
nkeehn's Avatar
Oil Pan Brace
Hey, does anyone make an add-on oil pan brace? Moroso builds one into their oil pan
http://www.moroso.com/catalog/catego...?catcode=12119
but it looks kindof flimsy. I kindof wonder how well designed it is as it is an X-brace, but the motor only spins one direction. Anyway, just wondering if some has tried to develope something better than that. Thanks
Old Sep 27, 2004 | 12:13 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Looks kinda flimsy???? How thick you wanting it man? The top flange is 3/8" thick billet alum AND has X bracing. What does the motor only spinning one direction have to do with anything?
It looks pretty damn strong if you ask me
Stephen
Old Sep 27, 2004 | 12:28 PM
fastrotaries's Avatar
W. TX chirpin Monkey
that thing is beefy.....How much further do you really need to go?
Old Sep 27, 2004 | 01:59 PM
nkeehn's Avatar
Aluminum is stronger in tension than compression so why not setup the brace with one thicker support in the optimal axial position instead of two crossing supports which only have one on the best axial position? Every little bit of stiffening the engine helps, though I think I might be over thinking this.
Old Sep 27, 2004 | 02:20 PM
diyman25's Avatar
RE for life
did any one know how much ?
Old Sep 27, 2004 | 10:46 PM
1st to 3rd's Avatar
Mod of elasticity of Al alloys is typically 2% higher in compression.
Old Sep 28, 2004 | 02:17 AM
andrew lohaus's Avatar
its an oil pan, not an oil brace, as long as it keeps the oil from dropping out the bottom its doing its job. the tension bolts are what hold the engine together.
even if it was strong enough for en elephant to sit on, there is only so much force that could be transfered through the stubby little bots that hold it to the bottom of the engine anyway....
Old Sep 28, 2004 | 02:39 AM
nkeehn's Avatar
Oop, my bad.. either way I'm over thinking this
Old Sep 28, 2004 | 08:13 AM
pp13bnos's Avatar
Pineapple Racer
I've been thinking about getting the Groundzero/Pineapple Racing oil pan. From what I understand it not only increases capasity and acts as a motor stiffener, but the pan is O ringed. So that means that there will be no more oil leaks for the guys making alot of power.
There was a thread about the new pan....but I can't seem to find it....I'll try to dig it up later. CJ
Old Sep 28, 2004 | 12:10 PM
HedgeHog's Avatar
Rotary Poseur
www.staffsauto.com
Old Sep 28, 2004 | 01:10 PM
ptrhahn's Avatar
Gotham has one too... I have one, my oil pan doesn't leak. Coincidence? You decide.
Old Sep 28, 2004 | 01:32 PM
Dwood432's Avatar
I have Gotham's too. I can take a pic if you want.
Old Sep 28, 2004 | 01:35 PM
SPOautos's Avatar
When you have the Oringed pan do you still used any silicone along with it? It seems like in the very tiny cracks and slightly unever surfaces along the bottom of the engine you would get small leaks, ect with just a oring cause it doest fill in around cracks and stuff like silicone will.
Old Sep 29, 2004 | 10:02 PM
Zero R's Avatar
Just in time to die
The o-ringed pan shouldn't need any sealent I've installed and sold many without sealant being used none have leaked so far,they offer much more rigidity as well.
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
