Power FC Comander got stuck on stupid!
Old Sep 22, 2004 | 04:40 PM
TwinTurbo93's Avatar
0-rotor-0-turbo-0-fd
Angry Comander got stuck on stupid!
Just the other day driving, I was looking at the water temp. on comander so I was gonna switch to se knock and other stuff, the SOB get's stuck, do whatever you want with buttons it stay's right there.
I turned of the car and flip back to ignition, now all I can se is 13b rew, I start the car, the same again, I reset the ECU by removing the neg. from the batt. for a min or 2, the same again,,,, I unplugged the ECU completely while the batt. is completely disconected, still the same after I put it back on... 13B REW, WTF!
The car seems to work fine, nothing changed to the way it worked from before.
Anyone got any idea what kind of problem this might be?
Thanks in advance,
Old Sep 22, 2004 | 09:16 PM
wylie's Avatar
Do you know anyone with a FC and commander?
Use their commander and see if it does the same.
Just a thought.
Check pins and all grounds.
Old Sep 22, 2004 | 10:39 PM
spoolin93r1's Avatar
mine does that every now and then. the plug for the commander just needs wiggled into my datalogit box and all is good
Old Sep 23, 2004 | 11:39 AM
Just a thought.
I do actualy, a friend of mine has a pfc and com. I'll give it a shot.
How do I check the pins, just clean them up, sort of?
The werd thing is that I had to make my own groung for the power fc box b/c the stock brackets wouln't fit on the holes, I know the groung is good and I made sure to check that the first thing.
I don't have datalogic but I'll be sure to wiggle that ***** good and clean the pins as much as I can.
I'll keep you'all posted, thanks for the help.
Old Sep 23, 2004 | 12:20 PM
RotorJoe's Avatar
Hooray For Boobies!!!
Could the comander have been damaged or like stated above, bent pins (shorts/opens)? I have heard of bad/damaged commanders doing this. They say not to drop it or hard shocks/jolting. Mine is not bolted down and I am lucky I haven't broken it.
But I know when you run a laptop with datalogit and you do the trace/monitor function it locks up the comander. But the screen stays and freezes on the screen you were watching (does not go back to the "13b REW" screen). Once you stop the trace/monitor the comander jumps back to life and updates it's self. So this is is different issue that I just wanted to point it out incase we are confussing the two. But after loocking at your mods, you don't have a datalogit.
Good Luck. Try a Buddies Comander.
Old Sep 23, 2004 | 02:05 PM
Well, it's almoast brand new and damn if it's already brocken, never dropped it or anything, I got it velcro-ed next to the head unit at all times.
Right, I don't have datalogic, I was just sort of scroling through it when it froze !!!
It'll be a while till I get to see my buddy to swap comanders.
Old Sep 23, 2004 | 11:53 PM
RX7UP's Avatar
BOYCOTT EXXON MOBIL!!!
Red face
Damn thats Fuzked up! My Fazher is a computer Engineer. Maybe he can Fizx it!
RX7UP
befarrer
15
May 19, 2022 10:44 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
subeone
Sep 24, 2015 09:58 PM
