engine dies when gas is given?!
Old Sep 15, 2004 | 03:39 PM
Thrasher's Avatar
Boosted GTUs
When its idling if I go to press the gas it will instantly die unless I really play with the throttle. Dosn't matter if I give it a little gas or alot it will still die unless I basicly pump the **** out of the pedal. Now I have a few assumptions #1 my fuel filter is old and clogged to hell but once I get it above idle it will hold whatever rpm I want to hold it at solid. #2 I may have hooked the injectors up backwards, I know I have the primaries and secondaries right but I may have rotor 1 and 2 swapped. the was a tag on the one injector wire for both primary and seconday injectors, I assumed this was the front rotor is this right? Does it matter? #3 maybe my fuel pump sock is clogged again look at number 1. #4 ... I dunno got any suggestions?
BTW the car is a 1990 n/a GXL
Old Sep 15, 2004 | 03:57 PM
DarkAngelKamui's Avatar
Beat Ninja
Sounds also like you may have an AFM problem....
Old Sep 15, 2004 | 04:04 PM
NYRX7's Avatar
I had a similiar problem once, turned out it was my map sencor.
Old Sep 15, 2004 | 04:08 PM
Thrasher's Avatar
Boosted GTUs
afm prob hmmm is there anything to do to remedy this other then get a new afm?
Old Sep 15, 2004 | 04:09 PM
Thrasher's Avatar
Boosted GTUs
btw second ges don't have map sensors.. they have that damn afm instead
Old Sep 16, 2004 | 01:39 AM
Thrasher's Avatar
Boosted GTUs
bump
Old Sep 16, 2004 | 04:45 PM
SOIA's Avatar
Take A Look Around
AFM is an easy fix usually, just disconnect the plug on top and clean both ends of the connection with electrioncs cleaner spray let dry and reconnect, and that should hopefully solve your prob.
Old Sep 17, 2004 | 11:42 PM
Thrasher's Avatar
Boosted GTUs
ok I cleaned the crap out of the afm connector at both ends.... good thing, plugs in easier, bad thing is the problem is still there. I also noticed I'm getting the 3800 rpm hessitation. just so I ease my mind what plugs go to witch injectors... I really have a feeling thats my problem
thanks Zach
Old Sep 17, 2004 | 11:50 PM
RXciting's Avatar
GrapefruitRacing?
while your car is down and no one else has given you an answer start checking your fuel pump see if the sock os clogged get a new fuel filter since you probably need one anyways
and do a search for the FSM (factory service manual) and if you don't already have one get a haynes if you can't find the FSM cause that, i guess, should be able to tell you what wire goes where
Frank
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
86glxNA
Aug 22, 2015 08:54 PM
smikels
Aug 18, 2015 01:26 PM
