clutch fluid
Old Nov 24, 2001 | 05:11 PM
gamble302's Avatar
roadkill hats rock
clutch fluid
what kind of hydraulic clutch fluid do you guys recommend, 85 gsl?
Old Nov 24, 2001 | 05:27 PM
eddierotary's Avatar
back with rotaries
i dont know, but i use brake fluid.
Old Nov 24, 2001 | 05:40 PM
gamble302's Avatar
roadkill hats rock
stupid ups, my factory manual was supposed to be here the 21st dag nabbit, im sure it would tell me
Old Nov 24, 2001 | 07:12 PM
Acuspeed's Avatar
I use Castrol GT LMA (it's brake fluid, o' course). Dot 3 and 4 spec.
Old Nov 24, 2001 | 07:29 PM
back with rotaries
i recomend dot 4
Old Nov 24, 2001 | 07:52 PM
cjf's Avatar
cjf
whats the big diff between dot 3 or dot 4????..Can you mix them. ( not that I want to but just in case it happens)...I had a 83 gsl and it needed brake fluid so I put in 3 but it could of had 4 in it.. ...just asking>>?%^$$&^&%^&^&^&(*^*....cjf........
Old Nov 24, 2001 | 09:05 PM
Pele's Avatar
Right near Malloy
4 has a higher boiling point. 3 is cheaper. If it uses 3, you can use 4 as well. If it uses 4 only, then do not use 3... If you race, you should probably use 4.
DO NOT USE 5! 3 and 4 are alcohol based, I believe. 5 is silicon based. It is not compatible with 3/4 seals or the fluid itself.
Old Nov 25, 2001 | 01:28 AM
gamble302's Avatar
roadkill hats rock
ok so basically im supposed to use dot 4 brake fluid? dont wann mess it all up
Old Nov 25, 2001 | 08:49 AM
peejay's Avatar
Old [Sch|F]ool
3 should be *fine*. The clutch hydraulics don't heat up like the brake hydraulics do, so boiling isn't a problem.
Don't get me wrong, I have high-temp synthetic DOT4 in my brake system. (Even better than the Ford 550deg stuff!) Weeny little 7-inch discs and 6.5"(?) drums make lots heat. But you're supposed to throw away unused brake fluid after opening the cap, so when I had to do my clutch hydraulics I just picked up a pint of the cheapest DOT3 available... for what the clutch hydraulics have to do, it's more than good enough.
FWIW I also laugh at braided steel clutch lines.... Clutches are a low-pressure high-motion system and don't benefit like the brakes, which are high-pressure low-travel. (Or at least the should be. )
Old Nov 25, 2001 | 03:13 PM
Pele's Avatar
Right near Malloy
If you have a stiffer pressure plate, they are actually supposed to help.
Hipsiguy
Sep 14, 2015 05:25 PM
Evan Kurtz
Sep 13, 2015 08:40 PM
