honda coolant premix?
Old Aug 14, 2004 | 03:01 AM
ManGaZeRo's Avatar
Living the Dream
My friend is a master mechanic at a honda dealer, he is going to throw up the car to check for any leaks and problems. He also said he will flush my radiator and put in honda premixed coolant. My question is will this be fine in the rotary and has anyone have experience with this coolant. My friend also knows this isn't just a typical engine. I don't doubt his knowledge of cars from his experience but I just want a second opinion.
Old Aug 14, 2004 | 09:54 AM
Slam Pig
im guessing its exactly that, premixed coolant....ie water and coolant premixed....
why not just ask your friend what it is
Old Aug 14, 2004 | 10:02 AM
SurroundedBySe7ens's Avatar
Well there isn't really different coolants for different cars, so I'm sure his "Honda Premix" will work just fine lol...
Old Aug 14, 2004 | 10:51 AM
Bad_Karma7's Avatar
7th heaven
It's probably ok, but make sure it doesn't contain any methanol. Methanol and aluminum is not a good combination.
Old Aug 14, 2004 | 11:10 AM
BigIslandSevens's Avatar
correct
I am also a trained Honda tech.( I can cook rice ) it is just a 50/50 mix. Safe for aluminum and all other systems. You will just pay out the *** for the speacial HONDA name plate. ( Maybe if it is MUGEN coolant it will work better as well!
Old Aug 14, 2004 | 11:32 AM
Meiogirl's Avatar
the REAL deal
yes there are...Dexcool, an orange coolant is typically used in GM vehicles.
G-12,pink coolant, which is typically used in volkswagens (found out when I did a google for Dexcool).
http://www.baldwinfilter.com/engineer/99_2.html
Old Aug 14, 2004 | 01:27 PM
ManGaZeRo's Avatar
Living the Dream
Well I am just afraid of the distilled water or non distilled portion of this mixture whichever it uses.
Old Aug 14, 2004 | 03:50 PM
mad_7tist's Avatar
distilled water is something that i agree seems like a great idea but i have seen no proof of it being any better. toyota has their own coolant also. if you mix them the rust inhibitor packages dont last as long
LongDuck
Oct 7, 2015 08:12 PM
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
musker
Oct 1, 2015 05:58 PM
