Power FC What size BUNG should I weld on the MP?
Old Jul 29, 2004 | 11:28 PM
BATMAN's Avatar
for the wide ban O2 sensor?
Old Jul 30, 2004 | 10:13 AM
radkins's Avatar
It's the standard O2 sensor size. Not sure what it is, but I believe they are all the same. I have had several put in by muffler sops and was never asked what size I wanted, but they all worked.
Old Jul 30, 2004 | 01:40 PM
BATMAN's Avatar
is there a prime spot to weld it?
front section of the MP or towards the rear?
Old Jul 30, 2004 | 05:18 PM
cewrx7r1's Avatar
Eye In The Sky
Depends if the sensor is a self heating sensor or not.
Self hearting, anywhere. Otherwise in downpipe.
Old Aug 2, 2004 | 12:27 AM
m18 by 1.5 I believe
Old Aug 2, 2004 | 12:29 PM
RotorJoe's Avatar
Hooray For Boobies!!!
http://www.innovatemotorsports.com/x...cat=250&page=2
Innovatemotorsports has the bungs and bung plugs to install into the DP. When I replaced mine I could not find anything at a hardware store that would work. When I called them (Innovate) they said it was a "pipe fitting" and the thread was tapered? Go figure. Anyways heres the link to buy more. Expensive yes.
I mounted my 02 sensor about 4 inches down the DP. I placed it down the pipe a ways to avoid excessive heat.
Good Luck.
Old Aug 2, 2004 | 06:33 PM
jpandes's Avatar
Mine installed at the end of the DP closest to the MP Flange.
Old Aug 8, 2004 | 11:22 PM
FCdemon's Avatar
3rd gen junkie
it needs to be installed somewhere that is easy to reach but won't burn the wire. my wideband bung is welded on the drivers side of the DP pretty near where it turns under the car. that way the wire can come straight up thru the engine bay and not get singed by touching anything.
Old Jul 26, 2006 | 04:02 PM
desmond's Avatar
I believe reading somewhere that you have the plx m-300 wideband. is your bung welded in your downpipe or mp/hi-flo? also is the sensor they supply self heating? i know i have a bung in my high flow, but im not sure about the downpipe.
Thanks
Old Jul 26, 2006 | 05:55 PM
DaleClark's Avatar
RX-7 Bad Ass
I had a bung added to my downpipe - just marked on the pipe where the sensor should go and took it to a local muffler shop. Told them to install an O2 bung on the spot I marked - he had the bung in stock, welded it on, and gave me a plug to put in it until I get my wideband. Did it while I waited, cost like $20 if that.
Most any muffler shop worth their salt will have those bungs in stock - this is SUPER easy for these guys.
Dale
Old Jul 26, 2006 | 09:15 PM
desmond's Avatar
Dale
My question is whether it needs to be in the downpipe. I have a bung in my high-flow , before the cat and was wondering if that will suffice. Thanks for the response though.
Shainiac
Jul 17, 2019 02:20 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
