walbro 255 with stock wiring
Old Jun 13, 2004 | 10:16 PM
torean's Avatar
vac leak
searched..but havent seen anything i was looking for....
looking to install a walbro 255 and want to know if its enough just to wire through the stock pump wires..most people upgrade the pump AND rewire at the same time...i dont think i need to rewire the pump with my mods....i dont want to be wasting fuel when i dont need to..would a RRFPR help?
RB 2.5DP, MP, K&N FLIP intake, FCD, stock catback
thanks
Old Jun 13, 2004 | 11:04 PM
Turblown's Avatar
Turn up the boost
I did not have to on my car. I tested the voltage at the pump while on and off boost. 13.65Vs the entire time, but I also have an fd alternator on this car.
Old Jun 14, 2004 | 12:36 AM
NZConvertible's Avatar
I'm a boost creep...
The Walbro draws a lot more current than the stock pump. Logic says you won't get the pump's full performance through wires sized for a much smaller pump. The rewire's not hard, just do it.
Old Jun 14, 2004 | 09:43 PM
RETed's Avatar
Anything is better than the stock set-up you have now, but I would highly recommend to rewire it.
If you got the money, there are fuel pump voltage regulators that make this a little bit easier, but expect to pay several hundred dollars for these things.
Kenne Bell Boost-A-Pump
Jacobs Electronics has one also.
MSD also makes one.
-Ted
Old Jun 14, 2004 | 11:12 PM
torean's Avatar
vac leak
may be a stupid question...but are there any writeups for fuel pump rewire?
Old Jun 14, 2004 | 11:40 PM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
yeah try this
i havent done it yet ,, but i might soon enough re wire write up
Old Jun 14, 2004 | 11:47 PM
torean's Avatar
vac leak
thank you very much sir
Old Jun 15, 2004 | 12:37 AM
Originally posted by torean
...are there any writeups for fuel pump rewire?
This is probably the best one:
http://www.1300cc.com/howto/how2/rewire.htm
If you search you'll find many threads discussing this.
Old Jun 15, 2004 | 12:42 AM
powrdby13B's Avatar
i'll blow YOUR valve off
just using bigger wire should do something shouldn't it? just pull the wires and replace with bigger ones...
Old Jun 15, 2004 | 11:17 AM
SureShot's Avatar
Seduced by the DARK SIDE
That's almost as much work as adding a power wire with a relay in the back.
Old Jun 16, 2004 | 02:00 AM
If you actually followed the very long fuel pump power path, you'd quickly see that that'd be ten times as much work.
streetlegal?
Mar 17, 2022 02:46 PM
rotor_veux
46
Jun 12, 2018 10:39 AM
Jmolina0163
Oct 3, 2015 10:04 AM
