I broke this..:(
Old Jun 2, 2004 | 07:49 PM
CARLiTO_'s Avatar
I broke this..:(
I was following Pratch's guide to removing the rats nest, but I broke a connector on the purge valve. I broke the connector for the 5/16 hose. Is there anyway around it? reason I am asking is because First gen parts are hard to come around here.
Old Jun 2, 2004 | 08:09 PM
pratch's Avatar
Mazspeed.com
Do a search for peejay and PCV...
at least I think it's peejay's idea. - Carl? Care to chime in?
Old Jun 2, 2004 | 08:16 PM
Rx7carl's Avatar
Airflow is my life
Thats what I'd do.
Haha WWPJD
Old Jun 2, 2004 | 08:31 PM
pratch's Avatar
Mazspeed.com
ROFL!
Thanks Carl, I think
couldn't that also be... WWPBJD? or WWtBD?
Old Jun 2, 2004 | 08:34 PM
CARLiTO_'s Avatar
Originally posted by peejay
'79-80 had the charcoal canister as part of the air filter assembly.
I plug a PCV valve inline between the manifold vacuum source and the oil filler tube, then route the center housing's nipple to the "clean" side of the air filter.
Is this what u guys are talking about? If not, can u pls point me in the direction of the correct thread.
Since I have removed my ac, do i still need to use that white solenoid?
Old Jun 2, 2004 | 09:20 PM
Rx7carl's Avatar
Airflow is my life
Yup thats pretty much it. He also specifies which one he uses in another thread.
Nope, you can get rid of the solenoid for the AC if you dont have it.
ls1swap
Jun 3, 2024 03:25 PM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Sethix
Nov 3, 2017 11:48 PM
Andrew7dg
Aug 6, 2017 01:41 PM
wthx100
11
Oct 1, 2015 10:23 PM
