spark break up? or what?
Old May 28, 2004 | 10:02 AM
RX7WEEE's Avatar
Need a 20b FD.
Question spark break up? or what?
I got my M2 large SMIC on so i turned the boost and fuel up.
I'm running 12.5 psi.
It seems that in higher Rpms 7000-8000 the car is getting spark cut just like a very very very little bit. its not as smooth up there as it should be. I thought that i wasn't getting enough fuel up there so i richend it up even more with the PIM volt it didn't make any differnce
I dont think that I am running too much boost to need to upgrade the ignition yet.
Am i wrong?
Or is there something else that it could be?
i have searched but i couldn't find anything that helped me any links or info would be helpful.
my mods
DP, MP, CB, apexi intake, racing beat spark plug wires, powerFC, M2 large smic, light weight pullies.
Old May 28, 2004 | 10:09 AM
dis1's Avatar
www.silverbulletrx7.com
Try replacing the plugs then throw it on a dyno.
Old May 28, 2004 | 11:05 AM
RX7WEEE's Avatar
Need a 20b FD.
plugs are fairly new but ill try that
Old May 28, 2004 | 11:15 AM
mad_7tist's Avatar
how old are the coils? make sure the ground is clean and good, all of them actually
Old May 28, 2004 | 12:00 PM
KaiFD3S's Avatar
SINFUL7
check your fuel pressure also
Old May 28, 2004 | 12:05 PM
matty's Avatar
i get this is as well but it happens when i run greater than 14psi...i need an amp.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
