turbo size
Old May 25, 2004 | 08:16 PM
soyo's Avatar
turbo size
I'm curious what size turbo would be recommended to run mid or low 12's(with proper fuel and a/f controll and everything else ofcourse) yet not have a ton of turbo lag as it would be a daily driver... if this is even possible... I don't know all the different turbo sizes yet as I'm just recently looking into a TII so any suggestions or info would be great
Old May 26, 2004 | 03:07 PM
Infini IV's Avatar
Microtech Tuning!
On a TII, a T04E "57" or "60"... or a T04B "H".... or a T04S (aka 60-1)
Old May 26, 2004 | 03:38 PM
soyo's Avatar
how much does a normal turbo upgrade cost? say with the T04E for example, how much would the turbo cost and installation and all
Old May 26, 2004 | 05:56 PM
Infini IV's Avatar
Microtech Tuning!
Wait... turbo upgrade as in bolting the compressor side to the stock turbine side (aka "compressor upgrade) or a full T4 upgrade (the full T04E turbo)..
How much installation and stuff costs depends on the shop...
Old May 27, 2004 | 01:18 PM
soyo's Avatar
T4 upgrade, any estimate or range on what a shop would charge?
Old May 27, 2004 | 01:40 PM
Infini IV's Avatar
Microtech Tuning!
You can find T04B's for around $500, T04E's for around $600-700, and T04S's for $700-800.
If you're looking to go cheap, you can use the HKS cast manifold which you can find for $250, and use the standard HKS 40mm wastegate which goes for around $250-300 as well...
Then you also need to have a downpipe made and various other lines and what not...
So all in all, your parts will cost you between $1,500 to $2000. Then you also have to figure in labor costs... And if you don't have the supporting fuel mods and engine management, you also need to factor that in...
Old May 27, 2004 | 06:11 PM
soyo's Avatar
ok so how much does it cost to rebuild the stock turbo? and will rebuilding it just make it work good again or will it do anything for performace, I don't think it does but you seem to know way more than me so I thought I'd ask
Old May 27, 2004 | 08:07 PM
Infini IV's Avatar
Microtech Tuning!
I think rebuilds cost around $300-500... Or you can get it rebuilt with an upgraded compressor wheel and housing while still using the stock everything else. Check www.rx7store.net and look under turbo's for 2nd gens.... Look for "87-91 Upgrades".
Old May 28, 2004 | 12:57 AM
soyo's Avatar
excellent... that would be more my price range haha thanks for the info man. if I have anymore questions I'll probably send you a PM... that stage 2 is looking mighty nice right now
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
Jmolina0163
Oct 3, 2015 10:04 AM
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
