GT35R Turbo Question
Old May 24, 2004 | 04:04 AM
akiabbasi's Avatar
Hi people
Is 450rwhp at 15psi achievable with GT35R on street ported engine?
If not what about GT40R?
Thanx
Old May 24, 2004 | 04:25 AM
Infini IV's Avatar
Microtech Tuning!
I haven't seen any dyno sheets of any GT35R's making over 400rwhp... Maybe I'm not looking hard enough...?
The GT40R *should* get you near 450rwhp @15psi though...
Old May 24, 2004 | 07:28 AM
akiabbasi's Avatar
is a Gt35/40 same as GT35R?
Also out of the 2 which one is mostly used?
Old May 24, 2004 | 07:41 AM
you arent looking hard enough Infini
Old May 24, 2004 | 08:21 AM
akiabbasi's Avatar
ok so it is possible to make 450rwhp at 15-17psi with GT35R?
Old May 24, 2004 | 08:28 AM
akiabbasi's Avatar
Old May 24, 2004 | 09:01 AM
CCarlisi's Avatar
Rebreaking things
Zoomzoom made 404 at ~15lbs on a reman at KD. However, they apparently wired up his crank angle sensors backwards so I believe he was running very aggressive timing (which would also explain why he lost a few motors on the dyno there). Since he put a street port motor in and fixed the crank angle sensor problem I believe the highest he has seen is 378rwhp at 15.5, but the motor was losing compression with each pull so that's not an ideal reference either.
Old May 24, 2004 | 04:28 PM
Infini IV's Avatar
Microtech Tuning!
Yes, GT35R = GT35/40
hey matt83usc, why do you say I'm not looking hard enough? Have you found a dyno of a GT35R making over 400rwhp ? If so, please post it... I'm interested
Old May 24, 2004 | 04:35 PM
Poweraxel's Avatar
do a search for GT 35/40 and you will find some dynos over 400rwhp at 15 psi.. of course good tuning is required!
Old May 25, 2004 | 12:25 PM
If there out there let's see them, I believe there is one, and it's on the dyno comparo site. Not exactly common.
Sorry it's been a year since I gave you all **** on this. Carl
smikels
Rtek Forum
May 12, 2016 12:34 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
Clacor
Aug 14, 2015 09:17 AM
