How do I get my brakes back?
Old May 22, 2004 | 09:31 PM
13BTOY's Avatar
Boosted Fb
I changed my front pads and now my pedal presure is lower than before. I must of bled the my brakes 3 times already and its still the same? Also why is there only 1 bleeder in the back? The car is an 83 GS.
Thanks, Ed
Old May 22, 2004 | 09:43 PM
RandyTibbles's Avatar
I suggest you buy a chiltons manual for it. You cold try bleeding it at the master . My guess is that you have air in the lie somewhere! that has got to be it , unless your master is going. Also, when you pressed the calaper in ...how hard was it to push? You did press the in didn't you?
Old May 22, 2004 | 11:47 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Did you blead it with it running?
Old May 22, 2004 | 11:54 PM
peejay's Avatar
Old [Sch|F]ool
Brake pads are often somewhat compressible until they are broken in. Drive it a while.
Old May 23, 2004 | 02:11 AM
Jeff20B's Avatar
Lapping = Fapping
Yeah, drive it for a while and hope the act of bleeding the brakes hasn't stressed the piston seals to the point of bypassing internally or leaking. How old is the master cylinder?
Hmm, I'm not sure about the bypassing internally part, but definetly look for any leakage down by the pedals.
Old May 23, 2004 | 07:03 AM
13BTOY's Avatar
Boosted Fb
Theres no way you can put the calipers back on without compressing the piston. Also I have been driving for atleast 400 miles. Theres no leaks and no the car was not running when I bled the brakes. Does it have to be?
Thanks, Ed
Old May 23, 2004 | 09:44 AM
BigJim's Avatar
trainwreck
hmm, i got my brake pads on without compressing the caliper, i thought it odd at the time, but they were ramanufactured calipers so i was like heh must be right.
Old May 23, 2004 | 12:43 PM
Jeff20B's Avatar
Lapping = Fapping
Loaded calipers come compressed for easy assembly.
diabolical1
30
Jan 30, 2016 05:50 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
Marty RE
Aug 13, 2015 11:19 AM
