Clutch slave/release line busted
Old May 22, 2004 | 09:42 AM
RotaryRyan's Avatar
DSM
Question Clutch slave/release line busted
well i was driving last night and all of the sudden my clutch just went to the floor with almost no pressure. I figured it was fluid leaking somewhere. anyway. the rubber line on the passenger side of the slave( or release...whatever you call it.) cylinder was busted.
I had no time to look at it last night, but do they sell this line or the whole cylinder assembly at autozone or advance or napa.
what is the best thing to do.
I gonna go to napa right now, but any other help is appreciated.
Old May 22, 2004 | 10:56 AM
Rx7carl's Avatar
Airflow is my life
The hose comes seperately.
Old May 22, 2004 | 11:06 AM
RotaryRyan's Avatar
DSM
alright is it like a universal hose or a special one?
Old May 22, 2004 | 11:17 AM
inittab's Avatar
I read your email
From what I can tell it's sorta on the special side. It might be a little hard to find without ordering. Of course, you could get lucky.
Good luck!
Old May 22, 2004 | 12:15 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I think there are two different thread pitches, so be sure you get the right one.
Old May 22, 2004 | 12:18 PM
Mr_Rx7_Au's Avatar
Aussie Rx7 Freak
The one that goes to the bracket attached to the firewall? that has a pretty common thread, should be able to get a replacement at any good brake and clutch garage
Old May 22, 2004 | 02:25 PM
Jinx099's Avatar
madatrix sells a stainless steel braided line exactly for your application. I bought this for myself and it has been working great. Keep in mind they WILL charge you $7 for shipping on it!
Old May 23, 2004 | 12:08 PM
pratch's Avatar
Mazspeed.com
That line was the first repair I ever did on my 7 - 10 years ago!
It's a dealer part, not too expensive, not too bad to change. I did it as the first car repair type thing I'd ever done. I hadn't even done an oil change yet!
Old May 23, 2004 | 01:48 PM
kiker14's Avatar
finally back in an RX-7!!
I have a similar problem, not sure if my hose is bad, or if I'm leaking fluid (haven't checked but my clutch is feeling a little weak) anyway, I had JUST bought and installed that hose for my FC before I ::coughcoughcrasheditcoughcough:: and was wondering if anybody knows if it's the same hose that an 87 fc would use? (into an 84)
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Inspector71
Aug 26, 2015 12:06 PM
