e-brake sucks
Old May 22, 2004 | 02:32 AM
Jinx099's Avatar
e-brake sucks
I like to show my friends a neat trick. The trick is where I go on a main road going 40 or 50 MPH and then I all of the sudden yank the e-brake. What happens?
Very slow deceleration!!!!
I never really worried about it, but I pulled off the e-brake cover off to adjust it because I thought that's all it was. The cable is now stiffer and the handle only comes up about halfway now, but it does the same thing!
Is there a different adjustment I need to adjust, or does my e-brake just suck?!
Old May 22, 2004 | 02:40 AM
680RWHP12A's Avatar
if you had drum brakes they would lock up......
easy,,,since you have a GSL its disk, so you can apply the brakes much harder berore they lock up....=better stopping power
Old May 22, 2004 | 02:43 AM
Gregs's Avatar
hey robert, are you as drunk as i am?
Old May 22, 2004 | 02:49 AM
Jinx099's Avatar
but pulling the e-brake up is equivalent to resting your foot on the brake pedal in terms of braking... should it be a lot more?
Old May 22, 2004 | 02:58 AM
wwilliam54's Avatar
it WILL run
make sure the e-brake cable isnt streched
Old May 22, 2004 | 03:36 AM
evil_motors's Avatar
Slide Or Die
william why does your icon look like a crx?
Old May 22, 2004 | 03:38 AM
wwilliam54's Avatar
it WILL run
it is
Old May 22, 2004 | 03:39 AM
680RWHP12A's Avatar
Originally posted by wwilliam54
it is
he is waiting for a 12A for his crx
Old May 22, 2004 | 03:45 AM
wwilliam54's Avatar
it WILL run
you confuse me
Old May 22, 2004 | 08:21 AM
peejay's Avatar
Old [Sch|F]ool
Re: e-brake sucks
You have a GSL?
The problem is you have rear disc brakes. Disc brakes suck for handbraking. Get rid of them for some drums, or just live with a handbrake that is almost sufficient to keep the car from rolling on a mild hill. (Twice now I've found my car rolled into the street, and my driveway is only like 5-6" rise over 10 feet)
Old May 22, 2004 | 08:34 AM
Illswyn's Avatar
<- because that guy is driving the CRX
Old May 22, 2004 | 10:18 AM
timmya2's Avatar
anyone know a skyline forum ?
Old May 22, 2004 | 12:14 PM
FirstGen7's Avatar
No. I don't know a skyline forum, nor do I have the inclination to ever visit one. You shouldn't either. :-P
I noticed this too, I was pulling into my driveway and pulled the E-brake, and it was also a slow decelleration.
I've got an 82 RX-7...so it's definitely not a GSL like yours...I do have drum brakes on the rear though.
It is possible that I wasn't going fast enough to notice a real hard braking...I'll have to experiment with it at faster speeds to be sure though.
And speaking of pulling E-brakes, my friend and I were touging on a back road last night in his Hachi-roku (Toyota Corolla GT-S...AE86, 4AGE) and came upon a turn where he pulled the E-brake, but kept it engaged too long, and we ended up doing a complete 180 and narrowly missing a mailbox...
I just about **** my pants, lol, but it was definitely a fun time...
Some old lady that had a house right where we slid out came outside and was all like "OMG OMG ARE YOU OK?!?!?!" My friend just said a deer jumped out, ;-)
Old May 22, 2004 | 12:37 PM
Dom's Avatar
Dom
callin' tokyo
Speaking of pulling hand brakes, over the winter I start my car up which was up on jack stands. I go into every gear and apply the e-brake. Well, it snapped off the last time I did that, and for now I don't have an e-brake.
Just thought I'd mention that so you have something to think about when you're doing 40 and thinking of pulling it.
Old May 22, 2004 | 01:22 PM
85rotarypower's Avatar
love the braaaap
THere were GSL's in 82 also buddy.
Old May 22, 2004 | 02:36 PM
FirstGen7's Avatar
Ah, slight misunderstanding there...
But I know that mine's not a GSL.
Old May 22, 2004 | 03:44 PM
wwilliam54's Avatar
it WILL run
no
Old May 22, 2004 | 04:03 PM
There is an adjustment for the ebrake cable. Get a Haynes manual baby!!!
Old May 22, 2004 | 05:40 PM
Lotus00's Avatar
I think he said he already adjusted it
Old May 22, 2004 | 06:20 PM
Pele's Avatar
Right near Malloy
Back when I drove my GSL, I used that lever behind the gear shift as a U-turn lever numerous times.
If it don't lock up the rears, something's wrong... I dunno what could be wrong if you've adjusted it, but something's wrong... Probably a stretched cable.
Old May 22, 2004 | 08:58 PM
All_Terrain_RX7's Avatar
On my 1982 GSL, the passenger side e-brake cable was "froze up", it would not move at all. I found this out while I was replacing the rear wheel bearings. I had noticed that my e-brake did not work right anymore, no matter how much I adjusted it. The e-brake only partially applied the driver's side brake. Since the other cable would not move, I could not get good pressure on the driver's side. I pulled the passenger side cable out, poured a little penetrant oil down the cable sheath, and started working the cable back and forth. It took a while, but it started moving. About 30 minutes of more oil and more working got it completely freed up. Quite messy. A local mechanic recommends STP oil treatment to lubricate speedometer cables, so I put some down the cable sheath before I put the cable back. Took a while to put the cable back. Seems to be fine now. My e-brake turn days are long passed though.
Yes, GSL's were out in 1982. I'm the original (and only) owner of this one.
djSL
The Bad & Fugly Businesses
24
Sep 21, 2017 03:09 AM
alexdimen
20
Oct 23, 2015 01:50 PM
