You want a custom sub box?
Old Nov 7, 2001 | 11:18 AM
DamonB's Avatar
I built a sub enclosure for my third gen that everyone thinks looks great. I build speakers as a hobby and this was a quick project. If you guys are interested I could supply this as a kit that you assemble; wood only. The enclosure holds one 10" driver and is built from 5/8" MDF with internal bracing; internal volume is about .75 cubic feet. It fits perfectly between the shock towers and the front is slanted to fit behind the trunk seperator. You must however remove about 12" of the foam padding under the trunk carpet to make the enclosure fit under the strut brace.
I would ask for $80 per kit + shipping to you. You would need to assemble the enclosure, add your wiring and upholster or paint it. Mine is in vinyl that matches the stock interior perfectly. I could cut custom holes on an indiviidual basis for additional money.
If at least 6 of you are interested I would do it.
Here are images links of mine installed:
http://albums.photopoint.com/j/View?...698&Sequence=0
http://albums.photopoint.com/j/View?...699&Sequence=0
http://albums.photopoint.com/j/View?...805&Sequence=0
Reply here or email me with questions; I would need to run them all at once as I have access to a CNC mill.
Old Nov 7, 2001 | 11:20 AM
DamonB's Avatar
ALright guys, you have to right click on the link and then cut and paste the image address into the address box. It works for me, let me know if it doesn't work for you.
Old Nov 7, 2001 | 11:35 AM
puma's Avatar
canadian monster
just put them smaller and insert them directly on the board
Old Nov 7, 2001 | 11:36 AM
MrFreeze's Avatar
right click each link propertys then select the address hit copy paste it into your browser and hit enter works fine
lenny's Avatar
looks like you cant go directly to the links, but if you copy the link and paste in your address box then it'll show the pics
nice design, is it easy to pull out and put in?
i heard that it is best to point the sub up at the rear hatch glass. how does it sound with the sub pointing back?
Old Nov 7, 2001 | 12:00 PM
DamonB's Avatar
Inside a small enclosure like a car, it makes absolutely no difference which way the speaker faces; the driver is just pressurizing the interior. I use a JL Audio driver and it sounds terriffic. To take it out all you have to do is remove the two bolts in each end of the strut brace and disconnect your wires. No problem.
I autox with mine installed; I never bother to remove it.
Old Nov 7, 2001 | 12:03 PM
Dimcorner's Avatar
Man Whore
I'd be interested, tired of my sub sliding around.
Old Nov 7, 2001 | 12:26 PM
spyfish007's Avatar
Yellow Dragon is no more
I really have to disagree with this statement. I have made several boxes with several different drivers to try in my RX-7 and position and direction of the driver are important. I too use JL and I've tried Dynaudio & Boston subs in my car too. I try it all. In my friends RX-7 from way back (2nd gen) we played around with 2 8's firing forward or backward. We decided backward sounded the best. I do agree that small cars are different beast, but I still think that direction and placement are very important.
Old Nov 7, 2001 | 01:12 PM
DamonB's Avatar
PLACEMENT can effect response in sub frequencies, DIRECTION does not. You can orient the cone of a sub any direction you want for a given point in space and get the same response, but moving the placement of the sub WILL affect response depending on if you have it postioned in a null or not for a given frequency. I spent weeks finding the best place for my sub in my living room at home.
Old Nov 7, 2001 | 01:16 PM
the_glass_man's Avatar
Will u do me a kindness?
WTF??? I still can't see it no matter what I do, copy/paste, etc... If I could see a pic that would help. Anyone have success with a sub in the spare tire well? That would be pretty trick if someone made a fiberglass kit for that!
Old Nov 7, 2001 | 01:26 PM
DamonB's Avatar
Right click on one of the links,
Go to "properties"
highlight the text in the address field
press "cntrl" and "c" at the same time
put your cursor in the address box of your web browser
press "Ctrl" and "v" at the same time
press "enter"
pic will display
Old Nov 7, 2001 | 01:27 PM
DamonB's Avatar
Go to "properties"
press "enter"
pic will display
With my enclosure I don't have to remove it to access the spare tire; one reason I made it like I did.
Old Nov 7, 2001 | 01:29 PM
puma's Avatar
canadian monster
yes i got it, just press the right button on the link and go to the last option than paste it on the adress box
man your installation is really clean, nice job.
I am not interested because i have already mine, a little bigger but...
http://members.sounddomain.com/pumalex
go and suscribe to sounddomain.com so that i would not be the only one FD
puma
Old Nov 7, 2001 | 01:34 PM
cool that worked thanks. looks nice.
Old Nov 7, 2001 | 01:42 PM
Does that 12" of foam that has to come out, have to be permeant? I meam do you have to rip out the foam and then once you do you can never go back? Because if it doesn't you might have your first customer!
Old Nov 7, 2001 | 01:57 PM
alaskan7's Avatar
That looks sweet
I'm undecided between getting a JL audio W7 or a polk momo, the W7 has a 8" mounting depth, would that fit in that box?
Anyone ever thought of mass producing sub boxes that would fit in our spare tire well out of fiberglass?
Old Nov 7, 2001 | 02:08 PM
Tom93R1's Avatar
gross polluter
That does really look good. Makes me want to finally get around to putting some kind of system on my car.
As for the fiberglass enclosure in the spare tire well, I remember seeing those for the FD several years ago at SoundTrack. It was in some catalog they had full of different hidden enclosures for all different cars. Last time I looked I couldn't find that one again. They must have discontinued it.
Old Nov 7, 2001 | 02:11 PM
Dimcorner's Avatar
Man Whore
no need to get too fancy here on my part... just want it to work and not slide... so how about some schematics
Old Nov 7, 2001 | 02:19 PM
FastX7's Avatar
I'd be interested in the kit if you're still going to make them.
Old Nov 7, 2001 | 02:43 PM
DamonB's Avatar
Sorry about the links guys, glad you figured it out. Removing the foam is not permanent. I sliced it with a knife and removed just the portion from the carpet that sits under the box. You can put it back later no problem and nobody will ever know. The box does not encroach on the spare tire it all; no need to remove the box just to get to your spare.
If 6 people tell me "yeah, I am in for $80 + shipping" I will do it. The parts are all cut on a CNC mill I have here at work, so you can be assured everything will fit perfectly. Assuming you glue it together right
I will provide directions and advice. Should take you only 1-2 hours at the most to assemble.
Email me at bottorff25@aol.com if you want and I can answer questions and forward pics if you still have trouble with the links.
Happy listening.
Old Nov 7, 2001 | 02:56 PM
DamonB's Avatar
puma
Gees, man. That thing is BIG! I would like to keep my windows in place thank you. My car is a daily driver so I have to be able to get groceries and luggage in there.
Old Nov 7, 2001 | 03:00 PM
Dimcorner's Avatar
Man Whore
blah.. blah.. blah.. If 6 people tell me "yeah, I am in for $80 + shipping" I will do it. ... blah blah blah...
Old Nov 7, 2001 | 03:19 PM
puma's Avatar
canadian monster
well it is big but i wanted something good and easy to remove. This is not my daily driver so...
if i would have want something to just have a little bass to improve sound, i would have probably do it the way you did yours. I also wanted something esthetic to do some import shows later in the futur.
by the way, i can remove it in 10 min when i go autoX or drag racing
puma
Old Nov 7, 2001 | 05:14 PM
DamonB's Avatar
Alright; I count two so far:
FastX7
Dimcorner
Anyone else interested? I need at least six to do it.
Old Nov 7, 2001 | 05:23 PM
dclin's Avatar
Perpetual Project
Whats the weight of the box/materials?
Thanks!
