1/4 mile time.......
Old May 16, 2004 | 04:24 PM
pimpncuba's Avatar
Replaced the Displacement
i estimated that my car will have 170hp after adding a rb exhaust. 135 stock + 5 hp (est.) for intake + 20% increase from exhaust = 170 hp. Does this number seem reasonable? i used this number in a calculator on www.rx7.com and it said with that amount of hp i would be running 14.5s in the 1/4 mile. Would this estimate be relatively close? does any one know what the 0-60 times might be with these mods? thanks.
Old May 16, 2004 | 05:05 PM
purple82's Avatar
Absolute Power is Awesome
My guess is that 170 is optimistic. It depends on the overall condition of your engine, but with stock porting and a free flowing exhaust, I'd guess you'll be around 145 or 150 flywheel HP.
Old May 16, 2004 | 05:09 PM
BigJim's Avatar
trainwreck
yea, i dont even think im at 170 rwhp and i have a stage 2 streetport with rb exhaust and cold air intake
Old May 16, 2004 | 05:15 PM
purple82's Avatar
I'm just under 170 RWHP with ALOT of engine, intake and exhaust mods on a high compression engine.
I've seen before that driveline losses are about 20% on these cars, so the 145 hp GSL-SE is probably at about 115-120 at the wheels, so about 15.5 quarter mile time.
Old May 16, 2004 | 08:16 PM
pimpncuba's Avatar
really? you guys think it will be that low? that kindof sucks. but i guess in a few weeks we will see how it works out
Old May 16, 2004 | 10:32 PM
peejay's Avatar
Old [Sch|F]ool
Re: 1/4 mile time.......
Max7 had pretrty much the same mods on his -SE and dynoed at 135 at the wheels, or about 150 at the crank.
He did run a car at 14.9 (different car, same setup) with a slipping clutch, at I think 2400lb plus driver.
Old May 16, 2004 | 11:34 PM
Max7's Avatar
Admitted Sevenaholic
peejay is correct, in my 84 GSL-SE with single RB exhaust, cone filter, working 6 ports, cold air intake, MSD direct fire, Secondary Throttle plates removed, 100k+ on motor and a slightly slipping clutch ran a 14.942 @ 92.61MPH running out 3rd gear on Nitto 555R drag Radials. at about 2440lbs no driver.
A fellow racer in his ITA 85 GSL-SE with stock motor and all the bolt ons, stripped interior and cage ran a 14.5 ish
a pic of both of us racing is here --> http://rx-7.org/events/images/Norwalk2000_final.jpg
He took 1st and I took 2nd out of 51 cars that weekend, show'd dem Hundaz a thing or two
Old May 17, 2004 | 01:02 AM
84stock's Avatar
What do you mean by secondary plates removed?? What did this do for you?? Just bought an se (have an 84gs)
Old May 17, 2004 | 08:23 AM
purple82's Avatar
Re: Re: 1/4 mile time.......
That's really light for an SE. There must be some interior parts removed. Normally, I'd expect a wet SE with driver to be more like 2600-2700 pounds. This is why my est. is at 15.5 sec.
Old May 17, 2004 | 08:26 AM
purple82's Avatar
The throttle bodies on rotarys have two sets of throttle plates in series.
Old May 17, 2004 | 10:55 AM
My se weighs 2440 with a full tank of gas, but that does not include me. With me included it is 2610.
Tylerx7fb
39
May 27, 2019 12:45 PM
Turblown
Time Slips and Dyno
11
Nov 20, 2015 07:20 PM
LMBTG
Aug 15, 2015 01:43 PM
