What are these hoses (right side of carb)
Old May 9, 2004 | 04:01 PM
JonnyOThan's Avatar
Newbie
Car: 1984 12A - Runs, won't idle.
I've noticed two spots on the right side of the carb that might be of importance - one where a hose broke and another that I'm not sure about. I've looked through the manuals and can't figure out what they are, so here's a pic.
The circled spot on the right is where the hose broke, and the one on the left looks like something is supposed to go there, but I'm not sure - it was like that when I got the car. Can anyone tell me what these are? Thanks.
Old May 9, 2004 | 04:26 PM
Fuel524's Avatar
i believe it is all emisions **** to fix it iether patch the crack (cheap way) or replace and find out if thats it i think that will solve your problem. i accidently forget to reconnect one of those after installing RB header and it ran shitty so just process of elimination but i think that would be causing you idle jacked up
Old May 9, 2004 | 04:35 PM
peejay's Avatar
Old [Sch|F]ool
The one on the left is I believe the AAV #1. Mine was leaking internally causing erratic idle. Some inventive plugging/capping solved that little problem.
The one on the right... look in the manual.
Jmolina0163
Oct 3, 2015 10:04 AM
sYnth.
Aug 19, 2015 06:27 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
pzr2
Aug 15, 2015 08:29 PM
