Fried a sensor on the emissions equip??
Old May 2, 2004 | 10:39 PM
The Spyder's Avatar
Never give up!
Yeah, so this went up in smoke the other day-
Whats it do?
Old May 2, 2004 | 10:56 PM
WAYNE88N/A's Avatar
that's your port air solenoid valve- it shouldn't have had any voltage going to it unless your 20K mile switch was screwed (should be no prob with it out of service)
Old May 2, 2004 | 10:57 PM
AcidShock's Avatar
Eet fase
Haha, how did that thing get toasted anyways?
Old May 2, 2004 | 10:59 PM
The Spyder's Avatar
Never give up!
My coolant fill necks plastic cracked and leaked antifreeze on it, went up in smoke, toasted the wires right off it.
Ok to leave it then?
Old May 2, 2004 | 11:01 PM
AcidShock's Avatar
Eet fase
Unless your car is under 20K miles, do not worry about it.
Old May 2, 2004 | 11:03 PM
The Spyder's Avatar
Never give up!
90k on this motor, 225k on the body
Old May 2, 2004 | 11:22 PM
SiGmA_X's Avatar
I thought it was 9k on the motor??
Old May 2, 2004 | 11:24 PM
The Spyder's Avatar
Never give up!
Ive told ya 3 times now.
Lay off the cronic!
Old May 2, 2004 | 11:28 PM
SiGmA_X's Avatar
So is it 9 or 90?
Old May 2, 2004 | 11:35 PM
The Spyder's Avatar
Never give up!
Old May 2, 2004 | 11:39 PM
SiGmA_X's Avatar
Humm, damn that cronic! I swear to dog that you said 9k when you first got it..
Old May 2, 2004 | 11:41 PM
AcidShock's Avatar
Eet fase
You bunch of Oregon peoples. Cracked out on drugs all the time.
Old May 3, 2004 | 07:14 AM
HAILERS's Avatar
HAILERS
No, not quite right. It always has 12v going to it on the black/white wire. These solenoids work by having a ground put on them by the ECU. That Port Air Solenoid is disabled at 20,000 miles by the ECU not putting a ground on it anymore after that figure. The black/white wire will always have 12v on it.
I'd suspect that the harness has been twisted and abused at where it enters the sensor and finally the black/white touched a ground *somewhere*.
Since the Port Air Solenoid is not used after 20,000 miles....then just disconnect the plug for it and tie it back.
imitek
24
Dec 1, 2015 03:35 PM
rotor_veux
Sep 19, 2015 07:13 PM
