Traction - Best Solutions
Old Apr 28, 2004 | 09:02 PM
RX7Wishing's Avatar
BOOOYAHHHH!
Hey all.. Im trying to find the best route to take in solving some minor traction issues.. My mods now are Apexi intakes, DP,CB,8.5 mm wires. When im getting on it first gear is basicly a lost cause at transition i get a plethora of wheel spin, Second gear at transiton i get wheelspin to. and besides feathering the clutch and playing with the throttle i need to know what mods i need to do before i start getting into more serious power mods. It would be pointless for me to invest the time and money into getting more power if i cant get it to the street and stick. I already plan on getting rid of the potenza 225's. But other then that, what do you guys/gals reccomend? What are you running suspension wise that has helped you out the most?
As Always Thanks!
~Jay
Old Apr 28, 2004 | 09:11 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
what cold tire pressure?
howard coleman
Old Apr 28, 2004 | 09:14 PM
Snook's Avatar
Tony Stewart Killer.
you are making ~245rwhp
+you have a problem with traction = stop asking dumb questions and get quality tires
its the only thing keeping your whole car on the road think about it
Old Apr 28, 2004 | 09:35 PM
iceman4357's Avatar
get trailing arms. My friend had some on his car and he said it made his car hook up so much better. They are reletively cheap as well. Around 200-250.
Old Apr 28, 2004 | 10:03 PM
RX7Wishing's Avatar
BOOOYAHHHH!
surge, im asking a serious question and as stated in my orignal post i said i was UPGRADING my tires and i asked other then that what can i do.. and as always, thanks for another one of your useless replies.
" I already plan on getting rid of the potenza 225's. But other then that, what do you guys/gals reccomend? What are you running suspension wise that has helped you out the most? "
Old Apr 28, 2004 | 10:04 PM
RX7Wishing's Avatar
BOOOYAHHHH!
thanks ice, ill look into that. witch set did he go with?
Old Apr 28, 2004 | 10:07 PM
Jim Swantko's Avatar
Racelogic
Old Apr 29, 2004 | 02:28 AM
Riccardo's Avatar
I wouldn't think you would be having such traction problems with your current set up, especially on US roads. I think once you have changed your tyres you will see a big difference - maybe you should consider wider rims as well.
In any case, you might also want to check your suspension set up, it could be that something is wrong there - for instance, I have Koni adjustables, and they were badly set up...once I put the same settings on all 4, the car handled much better
Hope this helps
Old Apr 29, 2004 | 04:03 AM
jspecracer7's Avatar
1JZ powered
run some 9" rims with 275+ sized tires. If your going to street drag, you could use the Nitto 555R's.
Old Apr 29, 2004 | 04:11 AM
ijneb's Avatar
FOR SALE
wider tires.
I've got 10 inches in the back (295's) and I rarely loose traction.
Plus 18x10's look bad ****.
Old Apr 29, 2004 | 05:37 AM
RX7Wishing's Avatar
BOOOYAHHHH!
Originally posted by ijneb
wider tires.
lol i bet... what kind of mounting issues did you run into? what rims you using?
Old Apr 29, 2004 | 08:39 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
really good tires
Old Apr 29, 2004 | 10:04 AM
rynberg's Avatar
There is no way you should be losing traction that badly at your current power level. Get some decent tires. Replace any worn out bushings in the suspension.
Old Apr 29, 2004 | 12:16 PM
fd3s_rx7's Avatar
BF goodrich will work
Old Apr 29, 2004 | 03:28 PM
ijneb's Avatar
FOR SALE
More pics here
Old Apr 29, 2004 | 11:44 PM
fd3s_rx7's Avatar
ijneb,
that's a hella clean black FD.
Old Apr 29, 2004 | 11:48 PM
tt2323's Avatar
Import Connoisseur
Like howard asked check your tire pressure, it could be to high. traction = bigger stickier tires
Sudowoodo
19
Dec 28, 2020 06:30 AM
Andrew7dg
Aug 6, 2017 01:41 PM
matty
47
Oct 4, 2015 02:45 PM
WANKfactor
Sep 29, 2015 01:14 PM
