87-91 engine swap question
Old Nov 3, 2001 | 05:33 PM
fc3s94509's Avatar
Question 87-91 engine swap question
can anyone inform me on what needs to be done to put an 91 turbo engine in a 87 turbo II.
Old Nov 4, 2001 | 12:14 AM
fc3s.org's Avatar
OG
Either a new ECU, aftermarket ECU, or change out the dash and use a 89+ ECU harness and engine. Also need the 89+ AFM from a TII
Or you can splice the 89 + motor into the 87 harness, which is what I did but it is very indepth and takes some time reading the FSM's for both years.
Old Nov 4, 2001 | 03:21 AM
fc3s94509's Avatar
do i just need to get a 91 ecu, engine wiring harness, and a 91 afm. can i still keep my dash. also is it possable to use just the 91 block and transfer all of the 87 parts to it .
Old Nov 4, 2001 | 11:46 PM
allstyle's Avatar
swap
I have had no difficulty whatsoever installing my 89+ motor into my 88. You will have to use your old injectors if you dont have the new ecu. The oil metering pump is electric on that motor. So it will not work. But no worries. Just use 2 cycle oil in your gas and you will be fine. I have been running this combo with various mods on my turbo II and I have had no problems.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
elfking
Aug 19, 2015 09:48 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
