To4s vs. To4r
Old Apr 26, 2004 | 10:46 PM
cripsR6's Avatar
11.7@128
Arrow To4s vs. To4r
can anybody give me some experienced based feedback on the two. I have researched and know some of the pros and cons, but would appreciate the advice of more seasoned enthusiasts. thank you
Old Apr 26, 2004 | 10:56 PM
Crusader_9x's Avatar
i had both and they both perform about the same but the t04r will make alot better power. it might come onlone just a hundred rpms or so off of the t04s but they will be close. i highly recomend the t04r.
Old Apr 27, 2004 | 02:24 AM
snapcaseacilec's Avatar
Bottled at the source
BY who though????
Old Apr 27, 2004 | 03:47 PM
cripsR6's Avatar
11.7@128
thanks crusader, I kinda had my mind made up about the to4r anyway.good to know!
Old Apr 27, 2004 | 03:52 PM
sub-zero's Avatar
The new GT 66 wheel might even be better then a T04R, or the T04S. They all use the same cover.
Old Apr 28, 2004 | 03:15 PM
cripsR6's Avatar
11.7@128
is that a hks model?
Old Apr 28, 2004 | 10:37 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Sub Zero, I haven't heard of the GT 66 wheel. Who is the manufacturer for that? It sounds like an HKS model but I don't know. What info do you have on it? Thanks in advance.
Zach
Old Apr 30, 2004 | 03:58 PM
sub-zero's Avatar
Garret makes a 67mm - 63 mm in there GT series. Precision turbo calls theirs a PT 67. I really cant tell much difference by looking at the wheel what the hype is about compared to the old T series, but hopefully if I ever get all My parts I will be able to tell You how it compares to the T-72 I had last year.
Old May 5, 2004 | 12:45 PM
i have the T04r on my Fd, it spool not as quick as my T04e, but it made a lot more on top. I have the hks t04r kit.
Old May 5, 2004 | 02:00 PM
CCarlisi's Avatar
Rebreaking things
At what RPM does it begin to generate target boost?
I'm in the market for a single. Right now I'm leaning towards the T04s .70/1.00 intake/exhaust ar with a P-trim exhaust.
Old May 5, 2004 | 03:06 PM
my car hit 14lb just below 5200 rpm. the t04e is around 5k, i have a large street port motor.
Old May 5, 2004 | 03:47 PM
CCarlisi's Avatar
Rebreaking things
That sounds a little high compared to what I've heard from other people.
Old May 5, 2004 | 04:05 PM
RacerXtreme7's Avatar
NASA geek
You must be running with your wastegate open ALL the time, or your car has MAJOR issues.
T04E 14psi by 2800~3200 RPM
T04S (60-1) 14 psi by 3200~3800 RPM
T04R 14 psi by 3700~4400 RPM
These are estimates using my own experiances and MANY forum members (other forums as well). It all depends on your set up (manifold type, turbine trim and A/R, intercooler, intake, porting etc).
~Mike..............
Old May 5, 2004 | 05:41 PM
SPOautos's Avatar
Hey, where did my $$$ go?
Actually a lot of it would depend on what compressor and turbine wheel you stick in those housings.
STEPHEN
Old May 6, 2004 | 12:16 PM
i got full boost buy like 4400 with hks undivided.
Old May 9, 2004 | 06:18 PM
Sidestick's Avatar
I have an XS Engineering T04E kit, ordered with a 1.00 exhaust A/R to reduce backpressure. 15psi by 3500rpm, stock engine.
Old May 29, 2004 | 07:51 PM
Erdin's Avatar
Water Injection Specialist
Would it also not depend on what gear your in and what speed.
rgordon1979
40
Mar 15, 2022 12:04 PM
alfred1976
1st Gen General Discussion
Oct 1, 2017 09:51 PM
GKW
Sep 28, 2015 04:34 PM
dillrx7
Sep 7, 2015 09:38 AM
