share your wisdom on turbos
Old Nov 2, 2001 | 10:14 PM
BK480's Avatar
Lightbulb share your wisdom on turbos
My turbos recently grenaded and I need advice on whether to rebuild, buy reman., or possibly used. I am positive the rebuild will be extensive because the turbos now make a high pitch noise, meaning the are probably unbalanced or hitting the housing. Thanks in advance for any help
Old Nov 4, 2001 | 12:28 AM
hawaii rx-7's Avatar
imo, it's a good time to get a power fc and go single.
Old Nov 4, 2001 | 12:55 AM
luneytune's Avatar
Boostable
Do you still have any boost? If so what is it 10-8-10 etc.? High pitched whine will probabley not mean the housing is being hit by the compressor blades. More likely a bad bearing but not likely both turbo's unless the oil passages are plugged. Rebuild is a good way to go about $150 each turbo if you do it yourself and you get new bearings.
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
