blue smoke =(
Old Apr 18, 2004 | 12:13 PM
mungrin's Avatar
Unhappy blue smoke =(
i got blue smoke comin outta my 82 rx-7... sometimes when it idles, sometimes when it goes above 4500 rpm... is it bad, what does it mean, and can it be fixed? if it can be fixed... how much will it cost and how can it be fixed? thanks guys =)
Old Apr 18, 2004 | 12:30 PM
gonzz's Avatar
Most likely your oil seals
Old Apr 18, 2004 | 12:32 PM
mungrin's Avatar
is that a major repair or... i have no idea where the oil seals are... how big of a cost is it gonna be?
Old Apr 18, 2004 | 12:39 PM
gonzz's Avatar
If it's your oil seals you will have to take the eng apart and inspect all parts. If all parts are within specs just change the oil seals and a gasket kit. Price depens if you do it or someone else does. Oil seals cost 32.00, 12A gasket kit for 100.00. Get stuff from atkins rotary. They are vey good.
Old Apr 18, 2004 | 12:48 PM
vipernicus42's Avatar
Rotoholic Moderookie
Before you go looking at the internal stuff, check your Oil Metering Pump. There might be something wrong with it.
Remember, our cars are *supposed* to burn a little oil. They're designed to do that. So check your OMP, to make sure it's runnign properly. Rebuild kits for your OMP are $20 and it's bloody easy to rebuild. I could teach a fourth grader how to rebuild an OMP, but tearing apart your engine is not for the everyday joe (unless you want your car up for a few weeks while you figure out how to put it back together!). www.loweperformance.com sells OMP rebuild kits.
It's probably a good idea to rebuild your OMP anyway. After 20 years the rubber seals inside them tend to start going bad, and that can lead to the OMP failing. IF it fails, it won't pump oil into your intake anymore to mix with the air and gas. If it doesn't pump oil into the intake, your apex seals won't get lubricated and will snap. This is a bad thing! This is an expensive-as-all-hell repair.
So try that first.
Jon
Old Apr 18, 2004 | 01:04 PM
9d7gst's Avatar
Boss**"You scare customer"
If the omp was bad, he wouldnt be burning oil. My car is doing the same thing, but its not drivable.
Old Apr 18, 2004 | 01:29 PM
I never suggested the OMP being "bad" was the source of the blue smoke.
But if the OMP rod comes loose or brakes, the OMP defaults to "full open", which could give extra oil at idle...
Jon
Old Apr 18, 2004 | 02:52 PM
Illswyn's Avatar
Does it pump oil at idle? When I checked mine, I didn't see anything until the pedal was pushed.
ls1swap
Jun 3, 2024 03:25 PM
rx7inoregon
Old School and Other Rotary
Oct 1, 2015 12:44 PM
frosty1993
Sep 30, 2015 01:27 PM
dexter snoek
Sep 29, 2015 09:18 AM
