rear rotor heating up really fast
Old Apr 12, 2004 | 07:28 PM
lemonade's Avatar
You can choose this?
well, the title says it, my rear rotor header get cherry red hot before it even heats up to normal operating temp. i just filled the radiator with cooland, and reinsalled the oil pan which is leaking fron the plug i think. if that makes any difference. ithas also started running pretty rich.
Old Apr 12, 2004 | 08:04 PM
lemonade's Avatar
anyone?
Old Apr 12, 2004 | 08:18 PM
Lotus00's Avatar
well if its running really rich, then thats why your header is getting so hot. a LOT of unburned fuel is being burnt right in your header, causing it to heat up.
Old Apr 12, 2004 | 08:20 PM
lemonade's Avatar
could it only be running rich in the rear rotor?
Old Apr 12, 2004 | 08:22 PM
Lotus00's Avatar
If something is wrong with your carb I guess it could. I cant think of any other reason your header would be getting that hot.
Old Apr 12, 2004 | 08:26 PM
lemonade's Avatar
hmmm, thanks. ill have the guy who tuned it take a look
Old Apr 12, 2004 | 09:24 PM
85rotarypower's Avatar
love the braaaap
Definately running rich on the rear rotor. It is possible to run rich on just one rotor. That would mean that your carb is totally screwed. The orfice in the primary jet on the rear primary barrel could have opened up some how (can't seem how but its the best I can think of), causing more fuel to be sucked in and causing the rear rotor to run rich. This is really the only thing I can think of. I know this is possible though because it happened to me. My carb looked ok when i rebuilt it, but I ran it for the first time the other day and the front rotor is getting WAY too much fuel. If you look down the carb on my car you can actually see fuel dripping from the venturi. There is just so much there that it doesn't mix with the air and drops raw fuel into the engine. Needless to say its flooding itself out, and I am getting a different carb because as it is the carb is enough of a frankenstein from when I rebuilt it. So, new used carb is coming in my very near future (probably get one this weekend).
Old Apr 12, 2004 | 09:42 PM
lemonade's Avatar
its a not so old dellorto
Old Apr 12, 2004 | 09:44 PM
love the braaaap
Forget what i said then. I didn't know you had a dellorto. In that case, you could just have the wrong jet size in the rear barrel.
Old Apr 12, 2004 | 09:47 PM
Directfreak's Avatar
I am a Jeeper Now.
Check the spark plugs - See if the rear rotor is running richer than the front, by the color.
Old Apr 12, 2004 | 09:51 PM
lemonade's Avatar
the car was running perfect after the rejet...now its...
Old Apr 12, 2004 | 09:55 PM
lemonade's Avatar
also, is it safe to drive it in this condition? the air fuel ration is like this
-red rich
-red rich -its running here
-yellow rich
-yellow rich
-green rich
-green lean
-yellow lean
-yellow lean
-red lean
-red lean
Old Apr 12, 2004 | 10:01 PM
love the braaaap
I wouldn't drive it too much. With that header getting so hot, you could warp the mounting flange and make an exhaust leak.
Old Apr 12, 2004 | 10:07 PM
lemonade's Avatar
drive it to my mechanic?
Old Apr 12, 2004 | 10:14 PM
love the braaaap
Thats what I would do if I couldn't fix it. It sounds too complicated to me. Something is just not right with your carb.
Old Apr 12, 2004 | 11:30 PM
Swolbynos's Avatar
Newb
retarded timing on the rear rotor? as in bent distributer rotor.
just a guess, but get the carb checked out first.
Old Apr 12, 2004 | 11:49 PM
rxseven07's Avatar
Registered pimp
hmm, maybe your cooling passages could be clogged up or ur not getting oil into your rear rotor. just a guess though.
josef 91 vert
23
Sep 3, 2015 11:20 AM
Marty RE
Aug 13, 2015 11:19 AM
