If our turbos are watercooled, then....
Old Oct 29, 2001 | 07:49 PM
Question If our turbos are watercooled, then....
...why do they glow orange? I have a downpipe, and still boosting no higher than 10psi. It glows around the turgbos and right where its connected to the downpipe. first 2 inches of downpipe sometimes glows too.
Old Oct 29, 2001 | 08:10 PM
maxpesce's Avatar
Ex fd *****
The water cooling is just around the shaft bearing - the turbine glows red because rotary exhaust is way hot!
Old Oct 29, 2001 | 09:14 PM
atihun's Avatar
How many miles do you have on your car? List your other mods!
If you have a downpipe and are seeing your turbos glow at 10psi either you are driving your car extremely hard, or you may be looking at a main cat that is starting to get clogged, or your turbo control system may need some work.
Old Oct 30, 2001 | 12:34 AM
My only mod. is a downpipe and drop in K&N. I know I'm having turbo problems (hose, actuator or solenoid problems). My readings are 10-5-10, but suddenly drops down to 7 until redline. Also, sometimes when I shift really quickly from say 2nd to 3rd, it seems like it forgets to open some stuff. PSI would read 2psi around 3500rpm, and then it "remembers" or gets "unstuck" and shoots up to 10psi.
p.s. it has around 40K on rebuilt engine. TUrbos are '95 ones.
Old Oct 30, 2001 | 03:18 AM
Tobal's Avatar
yea mine tends to glow too, just like you described it.... I have a DP and catback
Old Oct 30, 2001 | 07:58 AM
Well, my primary turbo has always glowed on the exhaust side. When I sent my motor to Dave at KD, he said the primary looked brand new, with no excessive play. I'm now running an open exhaust and Mobil1, which both should aid in cooling the turbos, and the sucker still glows red hot.
Go figure *shrug*...
Old Oct 30, 2001 | 10:16 AM
thatoneguy's Avatar
When did you install the downpipe? I remember when I first installed mine, it thing glowed red for about a month. Then it went away.
Old Oct 30, 2001 | 12:00 PM
I installed it about a month ago. I've only driven it "hard" a couple times. Sometimes it glows, sometimes it doesn't....weird.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
