anyone eliminate stock ignitor?
Yes, I am running an Autronic SM2 ECU and an Autronic CDI box. Works aesome. Totally eliminated the stock ignition system.
It probably has something to do with your ignition outputs that you are feeding the CDI box with. What does it require Ve-, Ve+? Stock coils should work fine with the AEM box, so I would not think they are an issue.
What ECU are you feeding it with? AEM ECU? Power FC?
Originally posted by 93BlackFD
haltech e6x
i am set to constant charge, 3ms coil times, falling edge
i think it's because i did not shield the cables going to the coils, what do you think?
haltech e6x
Coil charge time does not apply to CDI units. You should set that setting to contant duty I am pretty sure. When set to constant charge, the ciol charge time setting will go away.
Is it 4 channel? You need a 4 channel CDI box to run a rotary's trailing ignition. (one input for the leading front, one for the leading rear, one for the trailing rear, and one for the trailing front.)
Check in this order:
Is it a 4-channel CDI? it Well, try this. For testing purposes ignore the trailing and wire both trailing ignition outputs to the leading coils. Set your trailing timing to zero and see if the car will run. If you are unsure, send me the model number of the AEM and I will look it up for you.
Does the AEM require a falling or rising output signal? My Autronics requires a rising output, but yours may be different.
Are you a member of the Haltech list on Yahoo? Someone there will more than likely square you away. if not, I can help get you going.
Originally posted by RETed
You sure it's not a 4-channel sequential CDI box?
-Ted
-Ted
Trending Topics
haltech said:
"Hello Brian,
With no ignitor i would suggest setting the CDI unit
with S2 on - such that it is setup to be triggered by a digital signal, set
the software up as contant charge, 3ms charge time output edge falling."
here's the CDI switch settings
Switch 1 Multi Strike Disable - S1 enables or disables multi-strike spark
plug firings. Disabling Multi-strike (S1-ON) makes engine timing much easier
to check. Enabling MultiStrike (S1- Off, Default) makes the engine run
smoother at low speeds.
Switch 2 Trigger Edge - S2 sets the input trigger edge that the C2DI uses
to trigger the spark plug firing. Rising edge (S2-OFF-Default) is used when
the C2DI is wired in AFTER the ignitor (Ignition Amplifier) or if the
ignition did not have an external ignitor and there is not one inside the
coils. Falling edge (S2-ON) is used when the C2DI is wired directly to the
ECU and the ignition trigger is a digital signal with high signifying dwell
time.
Switch 3 Wasted Spark - S3 programs the ignition for use on engines
equipped with a single coil per cylinder (720 firing S3- ON), or dual output
coil feeding 2 cylinders (360 firing S3-Off-Default)
i turned switch 2 on, so it *should* be right, no?
"Hello Brian,
time.
I"m gonna bump this to see if you ever got it figured out to not use the stock ignitors with the AEM and haltech.
I'll be running an E6K, but I'd assume they have similar features in this regard.
-Chris
-Chris
I spoke with 93blackFD and he said that he has since returned to the stock ignitor. FWIW. I guess I'll call steve and see what he thinks about doing this with the e6k if it works on the PFC.
Try lower the dwell time to around 2.5ms. If the dwell time is set too high, it'll cause the coil overheat and eventually fire them.
haltech e6x
haltech e6x
Hey Steve to get the aem cdi to work with a pfc without the stock ignitor did you have to do anything special.
When I installed mine without the stock ignitor it wouldnt even crank and then installed with the ignitor it fired right up.
Thanks
Thanks
The problem with the PFC or any plug and play system is that it still goes through the ignitor first before it gets to the coil, you'll have to bypass all the wires on the ignitor so that the AEM or any aftermarket ignition box reads the signal and amplifiers it. Otherwise, you won't see any signal to the input of the ignition box.
Thanks
Thanks
I had mine straight out of the pfc going into the aem input and out of the aem to the coils. I guess something wasnt hooked up right cause it didnt work. Maybee I didnt bypass something right, I dunno but it works now with the ignitor.
Thanks Steve
Thanks Steve
msilvia
28
Apr 14, 2016 12:58 PM
GKW
Sep 2, 2015 10:18 AM
