13b housings on a 12a
Old Mar 30, 2004 | 09:05 AM
ksjohn's Avatar
Newbie
Would you be able to put 13b end plates and intermediate plate with 12a rotor housings? It looks to me like it would be a quick way to get a ported 12a engine. Would I be able to use my 12a intake manifold and exhaust header. Thanks for the help.
Old Mar 30, 2004 | 09:06 AM
Siraniko's Avatar
RX for fun
you can swap all the cast iron plates...I prefer using 79-83...after that, the ports are small especially the center plate.
Old Mar 31, 2004 | 07:55 AM
ksjohn's Avatar
Newbie
So I can use the 13b plates with the 12a. It looked to me like the o ring seal grooves do not match up correctly from the 13b to 12a.
Old Mar 31, 2004 | 09:29 AM
Junia's Avatar
Uchinanchu
If its a pre 86 engine it should fit
Old Mar 31, 2004 | 05:32 PM
peejay's Avatar
Old [Sch|F]ool
Only '86-02 engines have the coolant seals in the side housings.
'74-85 4-port 13Bs use the same side housings as 12As.
Ciclovnz
Oct 18, 2015 03:04 PM
cdn
14
Sep 10, 2015 06:23 AM
Josh83rx7
Sep 2, 2015 05:57 PM
Inspector71
Aug 26, 2015 12:06 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
