Exhaust bolt
Old Mar 26, 2004 | 03:54 PM
Junia's Avatar
Uchinanchu
Exhaust bolt
I've been driving around on this problem for a while now and its getting really annoying. last time I changed the clutch on the car I had to undo the exhaust bolts a little so I could get some clearance by moving the header a little. Well, you know that feeling you get when you turn a bolt, where you just know something isn't right. Well, I broke one of the exhaust bolt and there is nothing to grab on to so that I can turn it. I took the header off all the way in hopes that there is a little bit of the bolt there to grab but the bolt broke off about 1/16th of an inch into the hole. What is the best way to extract the the rest of the bolt. I took out one of the other bolts and compared it with the broken one and there's about half an inch or so left in the hole. BTW the one I'm referring to is the one on the bottom left if you're looking right at the header.
Old Mar 26, 2004 | 04:24 PM
mazdaverx713b's Avatar
Have RX-7, will restore
you may have to drill it out if you can't grab it.
Old Mar 26, 2004 | 04:32 PM
cosmicbang's Avatar
Use an extractor? Shouldn't that have been a stud instead of a bolt? Maybe you had a lower grade fastener.
Old Mar 26, 2004 | 05:19 PM
Jeff20B's Avatar
Lapping = Fapping
I had to extract two broken studs in my 20B.
Old Mar 30, 2004 | 11:50 AM
what is your status on this??
Old Mar 30, 2004 | 12:00 PM
Junia's Avatar
Uchinanchu
I just went out and bought an extractor set from home depot, and also picked a new stud. Now all I need to do is find a drill that will fit in that tight spot because I can't get the bit straight with the one I have right now.
Old Mar 30, 2004 | 12:03 PM
i hope you are using an electric drill, not a battery powered one..
Old Mar 30, 2004 | 12:06 PM
RXTbone's Avatar
Use a Dremel with an angle adapter...
Old Mar 30, 2004 | 01:34 PM
weld a nut to the stud and grab a wrench.
FD7KiD
15
Feb 26, 2021 10:12 PM
astrum
24
Nov 15, 2017 08:44 AM
FD7KiD
Aug 17, 2015 11:50 PM
