12A distributor OK on 13B?
Old Mar 20, 2004 | 09:17 PM
bliffle's Avatar
I have a 74 REPU to complement my stable of 3 FBs, and it has a 13B with the old points type ignition. I cannibalized a wrecked 84GSL at the boneyard for distributor and coils ($20) with the idea of converting the REPU. That 12A electronic dist oughta be OK in the 13B, right? Right?
I guess there's a diagram at Mazdatrix.
B
Old Mar 20, 2004 | 09:42 PM
peejay's Avatar
Old [Sch|F]ool
Sure.
Old Mar 21, 2004 | 07:23 AM
bliffle's Avatar
Anybody know if the 12A and 13B distributors are interchangeable?
B
Old Mar 21, 2004 | 08:47 AM
mwatson184's Avatar
holley guy
Yes they are, i run a 12a dizzy on my tII
Old Mar 21, 2004 | 01:08 PM
Jeff20B's Avatar
Lapping = Fapping
The advance curves are different. I installed a 12A distributor in a GSL-SE. Hurray for me.
Old Mar 21, 2004 | 08:23 PM
peejay's Avatar
Old [Sch|F]ool
Different but no so's much that it matters.
Old Mar 21, 2004 | 09:36 PM
bliffle's Avatar
Is installation any more complicated than getting the dist gear orientation right and connecting into the old coil connectors? Remember, I'm converting from points to electronic with new coils and new distributor and nothing else.
B
Old Mar 21, 2004 | 10:19 PM
mwatson184's Avatar
holley guy
You have to get the gear right and get the timing set with a timing light. Hmmm, its not as easy as just using the same wires though, much of the ignition system needs to be rewired. I will try to find the writeup for you.
Old Mar 22, 2004 | 03:09 AM
mazdaverx713b's Avatar
Have RX-7, will restore
yes, do not forget to swap the coils as well...
vy_MR2
Sep 16, 2015 06:39 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
