3k rpm at 60mph wtus wrong?
Old Mar 20, 2004 | 01:35 PM
r0taryr0ck3t's Avatar
just as the title says.. my 84 gsl's rpm are seeming really high, but im not sure if its normal because it is my first rx7...doin 60mph in 5th gear its rpms are just barely under 3,000 is this normal and if not what can i do about it?
Old Mar 20, 2004 | 01:42 PM
Anthrax Mike's Avatar
never posts...
Normal.
At least as far as my cars concerned.
Also if your cars a five speed, i know this applies for most cars but I'm not as sure about RX's, instead of third being the direct drive. Direct drive being approximatly 1:1 ratio. It sometimes is bumped up. First is quite low, second still a reduction, as well as third but just slightly less so. And then fourth is near the 1:1, input/output ratio. With five being the overdrive. If this is so then three thousand isn't out of the quesiton at sixty miles an hour. Hell I cruise at 3,000 everywhere reguardless of gear.
Old Mar 20, 2004 | 01:47 PM
sweetege's Avatar
bzzzzzzzzzzzzz
yea thats definetly normal it's because mazda did'nt design it for a fuel efficient car they designed it to reach it's top speed and sound beautiful while doing it.
Old Mar 20, 2004 | 06:21 PM
peejay's Avatar
Old [Sch|F]ool
Your revs are below 3000 at 60 because you have an '84 and those had taller 5th gears.
Drove me nuts. For the longest time I never used 5th gear below 80mph. Engine's powerband is above 4k, gotta keep it there.
Old Mar 20, 2004 | 06:42 PM
d0 Luck's Avatar
raysspl.com
my GSL is at 60mph at 3k RPM's
Old Mar 20, 2004 | 07:15 PM
cpt_gloval's Avatar
KARATE EXPLOSION
my '84 does about 2800 in 5th @60mph. in fact my '83 did too, since it had an '84 tranny.
i usually stick to 4th until i pass 65.
Old Mar 20, 2004 | 09:34 PM
domesttuner's Avatar
CVPI rules the road
my 88 is at 3k at 70, just thought i would contribute
Old Mar 20, 2004 | 09:39 PM
He really is alive!!!!
Old Mar 21, 2004 | 12:00 AM
Sk8r_dude's Avatar
Zoom - Zoom...
normal
24seven_dada
20
Nov 10, 2018 12:03 PM
frijol
Microtech
Sep 23, 2015 12:51 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
