What do I need to bolt on a Holley 650 Double Pumper?
Old Mar 17, 2004 | 06:50 PM
RgrWalker's Avatar
I just recently bought a 1985 RX7 GSL that had Major Carb Problems. Would not squirt fuel into the ports.
So, today I ripped out the Rat's nest and took the Nikki Carb off.
What we have now is an Engine without a Carb.
My question is, What do I need to Bolt on a Holley 650 Double Pumper? I'm wanting to buy everything and hook it all up.
Thanks in advance
Ranger Rich
Old Mar 17, 2004 | 06:51 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
A 650 is too big to use on a stockport motor. Maybe on a bridgeport...
Old Mar 17, 2004 | 06:54 PM
RgrWalker's Avatar
hmm, So what you're saying is, if I get a Holley 650, then I'll have to Bridge port my Engine?
Street Port isn't enough?
Old Mar 17, 2004 | 07:09 PM
vipernicus42's Avatar
Rotoholic Moderookie
I like the way you think!
Someone says that the carb is too big and instead of thinking "ah, so I need a smaller carb" you think "ah, so I need a bigger port job"
Yeah, RB sells modified holley 465s for stock and street port. You *can* get away with a slightly bigger holley, but you have to be damn good at holley tuning (from what I've heard)
Jon
Old Mar 17, 2004 | 07:50 PM
gonzz's Avatar
I had a 650 DP on my SP 13B and it was to much carb. bought a 600 cfm. Will try it out next week
Old Mar 17, 2004 | 08:26 PM
rx-7ames's Avatar
will a holley bolt onto the stock intake manifold or will he need to buy a holley intake manifold with the holley. man that can get expensive. i wish i had that kind of money. until then, i think i'm going to get a sterling carb. a lot more affordable.
Old Mar 17, 2004 | 08:39 PM
RgrWalker's Avatar
I emailed Sterling, asked about the pricing. I may go that route.
Old Mar 17, 2004 | 08:45 PM
RgrWalker's Avatar
How much Horsepower is possible from Porting, Larger Exhaust, Hi-Performance Manifold and a larger Carb?
Old Mar 17, 2004 | 08:56 PM
mwatson184's Avatar
holley guy
That all depends on the porting work really.
Stockport good to around 150
Streetport between 170 and 185
Bridgeport around 220-240
Periferral 12a the highest i've heard about was in the 290s i believe.
It is cheaper, better gas mileage, more reliable, to go turbo unless your engine needs a rebuild anyway. Or you can always do both
Marques
Old Mar 17, 2004 | 09:26 PM
heb09's Avatar
I depends on how big the porting is. A 650 can still be way to big for a bridgy.
Old Mar 18, 2004 | 05:48 PM
peejay's Avatar
Old [Sch|F]ool
650 double pumpers are too big for many street V8s.
The problem is that all double pumpers are mechanical secondary carbs. It could work just fine *IF* you get a vacuum secondary carb instead of a double pumper.
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
