Hello and thanks
Old Mar 15, 2004 | 10:29 AM
Dirtleg's Avatar
Hello and thanks
Hey y'all this is my first post on this board but I've been visiting for about a week now. Just wanted to say thanks for the FAQ pages and the information available there. I acquired my car (84 GSL) about a month ago and she was running terribly. I want to thank Puaka (a friend who also uses thi board) for helping me diagnose the original problem (no secondaries, shutter valve stuck closed) and remove the rats nest. I also found the thread about converting to mechanical secondaries very helpful and did this last week. The improvement in acceleration is significant.
At this time the mods to car are as follows;
Racing beat header (not sure which one)
3 inch exhaust all the way back
rear koni adjustables with racing beat springs
Mechanical secondary conversion
front strut tower brace (made by me)
some idiot put 15x7 4x108 rims on it.(rides like ****) they have to go asap.
Thats all for now. Later, Dirtleg
Old Mar 16, 2004 | 05:04 AM
inittab's Avatar
I read your email
Welcome to the forum! I'm glad we were able to help ya out.
Old Mar 16, 2004 | 06:37 AM
Rx7carl's Avatar
Airflow is my life
Welcome to the club. Oh and 3" exh is too big.
Old Mar 19, 2004 | 08:50 AM
Dirtleg's Avatar
3" too big? What would be a better size pipe to run? Would I make more power with a true dual exhaust? If so what size? Too many Questions? Help I'm Stuck?
Old Mar 19, 2004 | 10:42 AM
Ludicrous's Avatar
Drive it like u stole it
Hey, Dirt... welcome to the board. Good people here, they'll help you.
Pics of the car?
Old Mar 19, 2004 | 11:04 AM
Dirtleg's Avatar
Digital camera currently in error mode. Still under warranty will have pics eventually
Old Mar 19, 2004 | 12:06 PM
Rx7carl's Avatar
Airflow is my life
2" from the ports. If you collect them, make it go into a 2 1/2" .
Old Mar 19, 2004 | 12:17 PM
red13brx7's Avatar
Yep that would be my suggestion.. 3 inch is too big and too loud for a N/A rotary you loose velocity.
Old Mar 19, 2004 | 12:32 PM
Dirtleg's Avatar
So if i were to go turbo 3" be allright you think? Hmm. Also from back in my chemical plant days a 3" pipe carrying a high viscosity fluid would flow roughly double that of a 2" pipe carrying the same fluid at the same backpressure. Not that it would translate in exactly the same way with an exhaust but still I wonder at times. Anyone have a yay-nay on the true dual idea. Rotary tuning is new to me and I'm just soaking up as much info as possible right now. (every reply turns into more questions. I need help)
Old Mar 19, 2004 | 12:37 PM
Rx7carl's Avatar
Airflow is my life
Well in an exhaust your dealing with pulses, not constant flow. You want maximum velocity with minimum restriction. You cant really have both. So you tune for the RPM band you expect to operate in. I hear true duals work great on stock ported engines, at the expense of more noise, but have no personal experience with them. 3" is what I see alot of turbo guys run, but thats another area I'm not overly versed in.
