Found out what happened to my eng
Old Mar 15, 2004 | 03:43 AM
gonzz's Avatar
Found out what happened to my eng, but need some help
My eng was giving me some problems after it warmed up. It would start no problem. I would drive for 30 min or so then shut it off and would turn over but not start. I started taking motor apart tonight and discovered what happened. I'm not a expert but need some help in finding out what happened. Engine had around 3000-4000 miles since rebuild. I noticed e-shaft play was a lot before I took front cover off. Took cover off and noticed some damage. Let me know what causes this because I'm leaning toward e-saft play being excessive. All rotor housings/end and side housings are good. Apex/side seals are perfect. two or three of the corner seal rubber inserts are torn probably from play. Let me know what you guys think. Going to put it back together myself this time using 12A plates/-se housing/S5 rotating assy and running a holley 600.
Pics of damage
Old Mar 15, 2004 | 06:39 AM
Pele's Avatar
Right near Malloy
Who rebuilt it?
Check it out. I knew I saw similar pics somewhere...
http://www.mazdatrix.com/faq/pulley.htm
Old Mar 15, 2004 | 09:30 AM
gonzz's Avatar
A shop in Las Vegas, NV
Old Mar 15, 2004 | 12:27 PM
Pele's Avatar
Right near Malloy
Take the engine back and bust some heads... They should know about this kinda stuff...
Old Mar 15, 2004 | 07:47 PM
gonzz's Avatar
I just talked to them. they will fix it..
Old Mar 15, 2004 | 08:00 PM
mazdaverx713b's Avatar
Have RX-7, will restore
good. its good that they warrenty their work. what do you think would cause your damage
Old Mar 15, 2004 | 08:03 PM
white84GS's Avatar
Yeah man take it back, its only been 3000-4000 mi, obviously they goofed, just tell em to fix the thing
Old Mar 15, 2004 | 08:11 PM
Tanjo's Avatar
Royale with cheese
Ya, and tell them that they better put a turbo on it for their ignorance.
Old Mar 15, 2004 | 08:36 PM
gonzz's Avatar
Don't know what happened. Going down there with the damaged parts now so they can look at it..
Old Mar 15, 2004 | 09:32 PM
RotaryRyan's Avatar
DSM
Hey i just saw your car. What kind of tail lights are those and did you make that back hatch? its nice.
Old Mar 15, 2004 | 09:34 PM
RotaryRyan's Avatar
DSM
i forgot to say who i was asking.---> Gonzz
Old Mar 15, 2004 | 10:19 PM
RotaryRyan's Avatar
DSM
Old Mar 16, 2004 | 01:42 AM
gonzz's Avatar
skyline lights.. Hatch is from Japan
whinin
Mar 30, 2019 07:53 PM
troym55
23
May 25, 2016 12:42 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
