wich one fires first
Old Mar 13, 2004 | 09:04 PM
eddierotary's Avatar
back with rotaries
i have a confusion about ich one of the timing fires first wich one fires first the leading or the traling? thanks
mazdaverx713b's Avatar
Have RX-7, will restore
the names leading and trailing should clue you in.
Old Mar 13, 2004 | 09:14 PM
mwatson184's Avatar
holley guy
Think about it this way. Looking at the engine from the front of the car, the engine rotates clockwise. On the main pulley, there is a yellow and a red mark. The yellow is for leading ignition, and is to the right of the red (trailing) mark. When the pulleys rotate clockwise the yellow (leading) will pass over any point before the red (trailing), so the leading must fire before the trailing.
Now that i read over that i'm sure i could have explained it better. But i think you should get the point.
marques
Old Mar 13, 2004 | 09:15 PM
and remember, people assume because it rotates clockwise that the trailing fires first. not true. like mwatson184 said, its all in the timing.
Old Mar 13, 2004 | 11:52 PM
back with rotaries
ok so heres another question wich coil is leading on the car? i always had the leading one on the coil near the engine, hayes book doesnt say wich one it goes were so im kinda worry that i have my timing screw up
Old Mar 13, 2004 | 11:59 PM
dbtolman's Avatar
I believe that the front coil is trailing, and the rear coil is leading. Kinda the opposite of what I'd expect, but hey... These things were built by aliens, so I hear.
ls1swap
Jun 3, 2024 03:25 PM
Aramir
Oct 18, 2015 02:39 AM
LongDuck
Oct 7, 2015 08:12 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
