Which Single Turbo? ??
Old Mar 12, 2004 | 10:35 AM
R1ownesYou's Avatar
R1ownesYou
Question Which Single Turbo? ??
i Drive a 93 R1. I'm having it rebuilt..ported,polished,clutch,front mount,alum radiator,3mm seals,ECU upgrade... My mechanic says i'll get 350 horses out of the stock turbos, but the other day i found out they're bad. So I'm gonna do the upgrade. I don't mean to ask a repetitive question on this board, but If i wanna swing 450rwhp and still keep it the daily driver around town.. My mechanic sugests T-78, but he's usind that turbo for over 600 hp...I want something with a faster spool.. I'm considering a t3/t4. td06. t78...any other suggestions or opinions?
Thanks
Josh
Old Mar 12, 2004 | 10:43 AM
onenrg1's Avatar
I have a GT35R for sale. It is good for about 600 hp and will spool up very quickly since its full ball bearing. When you hear that turbos are ball bearing its mostly just the front part of the turbo. This is garrett's new design. Check out the website and do some reasearch here. You'll see it is a very good turbo. I am selling it at $1000 and you can also see that that is a very good price. The turbo is new and unused. See my ad in the for sale section. Let me know if you have any questions. GT35R For Sale Good luck in your search. By the way my brother is going with a GT40 for his FD. Maybe thats a route for you if you want to make some high hp. It seems that a lot of FD's are using either those or the GT35R's in Australia. And one thing I have found is that those australians are crazy about hp. Good Luck.
Old Mar 12, 2004 | 11:09 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
TO4S/R are good as well. Very streetable.
Old Mar 12, 2004 | 04:05 PM
EVLFD's Avatar
I Need WHEELS ! !
T04r
Old Mar 12, 2004 | 04:19 PM
$150FC's Avatar
Currently Winning
t3/t4 is too small.
Old Mar 12, 2004 | 05:43 PM
Zero R's Avatar
Just in time to die
Originally posted by $150FC
t3/t4 is too small.
I love when I see this.
-Sean
Old Mar 12, 2004 | 06:25 PM
onenrg1's Avatar
I guess the first question that should be asked is how much hp do you want?
Old Mar 12, 2004 | 06:32 PM
Jim Swantko's Avatar
PTE 76 S-trim
Old Mar 12, 2004 | 06:47 PM
jcarranza03's Avatar
I'm putting in a t-70 in my 93 and looking to push at 400-450... I think, I hope. I'll let you know how it goes. And from all i've read by searching the threads to what my mech an I dissc. a t-70 was my choice.
BTW my situation is similar to yours except I got 2mm seals instead of 3. (bigger is not ALWAYS better) I'm not a big car tech. just a lover.
Old Mar 19, 2004 | 11:19 AM
DAVINCI MOTORWORKS CUSTOM AF22S. 60MM COMPRESSOR WHEEL, 4" INLET X 3" OUTLET 450HP CAPABLE. COMES WITH THE T-4 BASED 1.0 DIVIDED TURBINE. THIS UNIT SPOOLS QUICKER THAN THE STD 1.0 GARRETT TURBINE USING THE P-TRIM WHEEL... HAS AN INCREDIBLE RECOVERY SPEED, THIS UNIT PERFORMS AND SOUND AWESOME!
$875.00 FOR A SHORT TIME. OUTPERFORMS THE GARRETT TO4S HANDS DOWN!
Old Mar 19, 2004 | 08:34 PM
ManGaZeRo's Avatar
Living the Dream
std...eh...
Jan 11, 2016 04:08 PM
Aug 21, 2015 08:35 PM
