Nooooo Turbo help please
Old Oct 25, 2001 | 08:22 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I installed a manual boost controller today with no probs. set it to around 7 psi before hand using a air pump to test. so I start driving slowly to test it out. 7-8psi. but then I give it some gas again and hit 15!! but there wasn't any load on the engine so it's still fine. so I take a look under the hood. the metal niple on the top of the turbo that holds the vac. line to the wastegate came out of the turbo!! SH*T. I stuck it back in and drove around for 5 mins and it poped out again. so now it doesn't idle very well and boosts unlimited PSI...
Is the turbo going to have to come off to fix this? how can I fix it? The car isn't really drivable untill I do.
Old Oct 25, 2001 | 08:42 PM
Brian P's Avatar
This is the only thing that I can think of that will keep it in... knurl the surface of the tube if you can. this raises the surface and it should be kindof stiff going back in. You'll probably want to use some permanent loctite on it.
I don't really know any other way besides taking the turbo off, and tapping the hole with some pipethreads so that you could screw a nipple in, in its place.
I doubt any sealant that you could put on it will hold it in by itself.
Old Oct 25, 2001 | 08:51 PM
Scott 89t2's Avatar
SOLD THE RX-7!
yeah I don't think any sealent will hold it cause it's too hot there. it's already got a bit of a lip and it's kinda hard to get back it. it looks like it's only held in by a lip from the fatory.
dam... O well, I need to port it anyways just don't want to spend the money right now to take it off.
the only other thing I can think of would be to tack weld it back to the turbo. cuase once it's in there is no leak, it idles fine, but you can pull it back out with a bit of effert.
Old Oct 25, 2001 | 10:00 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Here it is.
it goes in and out kinda easy. I dont' know how to make it stay.
this sucks
Old Oct 25, 2001 | 11:27 PM
Scott 89t2's Avatar
SOLD THE RX-7!
going to try some JB weld tomorrow. hopefully that will work, I guess 5psi wasn't enough to push it out but 8 was.
Old Oct 25, 2001 | 11:50 PM
Erik's Avatar
Best of both worlds
do you have a TID mod? i can't even see my turbo with the stock tubing that goes down. or did you have to take it off to see the hose had popped out...
hope you fix it man
Old Oct 25, 2001 | 11:55 PM
Scott 89t2's Avatar
SOLD THE RX-7!
stock lines, stock airbox. I can see it and barely get my hand down there to get it in and out.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
